Home > Duckworth Parts > gearbox loom
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
gearbox loom
Hi Dan,
My garage is telling me that the gearbox is leaking from the wiring plug on the box and that the loom needs replacement.
VIN: SALLMAM237A243985
What's the cost and availability pls?
Pat
Post #450185 7th Sep 2017 12:33pm
duckworthparts
Site Sponsor
Hi Pat
going to need a bit more info, I don't understand how you have a leaking gearbox from a wiring plug on the loom?
also the gearbox loom is going to be part of the main body harness... You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #450198 7th Sep 2017 3:38pm
berkshirelad
Apparently, there is a wiring plug on the side of the gearbox.
I'll go back to them for more info. They say it is a common problem on the X5 with the same box.
Post #450203 7th Sep 2017 4:17pm
duckworthparts
Site Sponsor
yea my mind has gone blank Neutral unless anyone else can shed some light on here You can paypal direct using - www.paypal.me/duckworthparts
Post #450204 7th Sep 2017 4:22pm
berkshirelad
Right, I've been back to the garage.
The bit they need is the plastic 'sleeve' for the gearbox (mechantronix) connector.
I believe that the sleeve has a ZF part number of 27.520, but that there is a kit which also contains the gaskets.
This, although BMW shows a picture of it
http://www.ebay.co.uk/itm/BMW-ZF-OE-6HP26-...Sw6DtYWUy9[/url]
Post #450561 11th Sep 2017 3:35pm
duckworthparts
Site Sponsor
typically LR don't sell it separate to the bit of harness, would be £122 for that. BMW should be the same though? You can paypal direct using - www.paypal.me/duckworthparts
Post #450563 11th Sep 2017 3:40pm
berkshirelad
Thanks anyway Dan.
I'll order the BMW part - it's only £17!
Post #450681 12th Sep 2017 10:13am
