Home > Technical (L322) > Idle Speed
Closerthanmost
Idle Speed
Having had my FFRR for almost two weeks I'm loving it but I've noticed it sounds like it is over-revving when stationary.
Dial is showing around 700-750 which doesn't seem to be that high to me. Changing into Neutral doesn't seem to make any difference and I've tried turning everything off that I can in case it's a voltage variation as I assumed that would make a difference, but it still stays the same.
Am I being over paranoid ?
Thanks
Andy
Post #450187 7th Sep 2017 1:06pm
yep ....
idle should be like yours ,700'ish... ... - .- -.
Post #450189 7th Sep 2017 1:12pm
Closerthanmost
That's ok then. Thanks
I'll just start getting paranoid about something else now Smile
Andy
Post #450190 7th Sep 2017 1:15pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
owned a good few 6 cylinder engines of both flavours , all lazy at idle pal
Post #450191 7th Sep 2017 1:16pm
Billaboard
United Kingdom 2004 Range Rover Vogue Td6 Baltic Blue
I've been wondering the same thing on my 2004 TD6. It sounds and feels like the engine is turning much faster than the rev counter says.
I can't find it now, but in the past I've watched an online lecture about (probably Jeep) ECU's where it was said that the engine sends signals to the electronics, but the electronics is programmed to send out what you want to see to the gauges. In other words, you can't trust anything much on the dashboard displays.
I wish I could find the video. The speaker had taken a spare engine control unit, measured the signals in the car and set up a simulator.
I wondered whether my RR does something similar. Old 110 2.3 Petrol ???? - ????
Old 110 200tdi ???? - 2004
1996 Discovery 300tdi 2004 - 2015 met fiery end being welded
2004 JEEP Grand Cherokee 2015 - 2017
2004 L322 Td6 2017 -
Post #450213 7th Sep 2017 5:03pm
