![]() | Home > In Car Electronics (L322) > L322 Digital TV Upgrade Advice |
anorakmark Member Since: 18 Jan 2014 Location: Chatham Kent Posts: 121 ![]() ![]() ![]() |
Hi all.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
there's only one solution and that's to change the tuner to a hybrid one...loads on this do a search |
Thank you Stan, just done a search and loads of info, Thank you |
just to add, do you really want it?..the reception is restricted to strong signal areas and if you watch it for to long then the battery will go flat...and for the going rate of around £300 ,you can buy a nice flatscreen for the bedroom etc.. ... - .- -.
Hi Stan,
i know what you mean, my first FF was a 2005 with the touch screen nav and it didnt have a reverse camera which i was desperate to get , basically because i didnt have it...now i have it in my westie i hardly use it and use the wing mirrors to reverse.. ... - .- -.
That will probably be the same here, I will upgrade the TV and never use it.
the MOST system came out as early as 54 reg plates ...had yours have the earlier canbus system then fitting an android head unit would have been the way to go.... ... - .- -.
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 ![]() ![]() ![]() |
If you have a touch screen your VIN should be 5A****** which indicates Model Year 2005. MYs start from about September of the previous year depending on when LR roll them out.
Just checked on V5, mine starts with SALL****35A******
SALL****35A******
Yep Weggie, mine has the 35A in the middle, and I meant to put first reg end Sept 2004, not 2005
BTW, you're not the only one, but it isn't "Weggie" |
Corrected LOL Weegie |
