![]() | Home > In Car Electronics (L322) > how can i tell what sound system i have ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
use the vin decoder..
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
Ok stan , where is that situated ?
tired one using google and only reference to sound system is 'European radio tuner' nothing about HK on the spec list |
tired another one and got
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7849 ![]() ![]() ![]() |
The Vogue has Harman Kardon as standard, with the DSP amp.... it will not be Logic 7, that came with the touchscreen in later cars.
ah right , thanks pal , probably explains why its so sheet ! my mercs HK amp has failed , 960 of your fine English pounds to replace ! |
didn't get an owners manual with mine |
you can download your owners manual from the topic site... ... - .- -.
thanks stan |
That was from the sales brochure though....
ha , ok pal , anyways it looks like I can fit a sony set up that will partly incorporate the cars system "plug n play " so all being well in wont have to put up with all the antics the standard set up performs currently , where abouts in Derbyshire are you pal , im just north of Lincoln
Chesterfield mate. 2011 Range Rover Vogue SE 4.4 TDV8
ah right , not been there for a few years
