Home > Technical (L322) > rear window issue
vmaxer
United Kingdom 2003 Range Rover Autobiography Td6 Cairns Blue
rear window issue
hi peeps Very Happy been trying to find info regarding rear windows not working so i thought id put it here
1 start car rear windows come down wont go back up
2 put rear window lock on ,windows stay shut sometimes
bit of a '#'/ when its raining
any ideas 2003 td6 l322
Post #450033 6th Sep 2017 12:48pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
Is this from using the switches in the front or back?
Or both?
Post #450037 6th Sep 2017 12:58pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Could be an issue with the body control module under the passenger seat. Sometimes the circuitry/resistors can fail or connections can get loose.
My rear driver's side window only works when there is hot weather. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #450047 6th Sep 2017 1:57pm
vmaxer
Sorry from using front the not had chance to try back as I have to put the lock on
Post #450188 7th Sep 2017 2:10pm
hamlet
Just so I understand, using the switch in the front, the rear windows will go down but won't go back up?
It's not that the windows are going down on their own when you start the car is it?
If they will operate normally with the switches in the rear then there's a problem with the switch panel in the front, if they won't operate correctly with either the front or rear then you have another problem.
Is the global closure enabled on your car or have you tried letting the windows up using that?
Post #450193 7th Sep 2017 2:51pm
vmaxer
windows
hi no as soon as i put ignition on the rear windows go down Very Happy so i havto leave the rear window lock on ,then sometimes rear windows will come down as im driving so stop car hold rear window switches at front of car and turn ignition on and pray Shocked
Post #450194 7th Sep 2017 3:00pm
hamlet
Sounds like there's either a short somewhere (switches?) or a problem with the BCM.
Might be worth unplugging the switched in the rear behind the door card to see if that narrows down the problem.
And faults coming up?
Post #450278 8th Sep 2017 4:32pm
vmaxer
windows
ok thanks will be gettin stuck in as soon as it stops raining Rolling Eyes
Post #450394 9th Sep 2017 4:33pm
Balloonengineer
I had a stuck rear window recently. Pulled it down manually with a flat hand while holding the switch.
Was sticky rubber due to lack of use. A good dose of sillicone spray/grease especially on the top edge and its getting better with every use. Recommend doing them all as it takes a load off the motor and relays
Best wishes
Glen
Post #450438 10th Sep 2017 10:26am
vmaxer
thanks but it was the first thing i did Thumbs Up
Post #450447 10th Sep 2017 11:40am
I'd plumb for the BECM, they have small relays on the PCB which fail...
For a quick fix, whip off the door cards and unplug the motors when the windows are up...
A code read with an IID or similar may be worthwhile... Thumbs Up Pete
Post #450450 10th Sep 2017 12:06pm
