Home > In Car Electronics (L322) > Date set in Euro format
Simran0211
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Santorini Black
Hi all I have just realised that the date on my l322 is set in the wrong format it's set month day year does anyone have any ideas on how to set for the UK please.
Thanks in advance
Post #449968 5th Sep 2017 3:07pm
RRPhil
If your TD6 is a Vogue then I guess you have the sat nav system fitted? If so, just go through ‘SET’ to ‘DATE’ and you can change the format there
Phil
Post #449977 5th Sep 2017 4:17pm
Rob99
Slightly off topic but "How on earth did you get 31.5 degrees in Coventry?" Shocked Shocked
......or do you keep your fattie in a nice toasty garage Laughing Laughing 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #449978 5th Sep 2017 4:28pm
Simran0211
I have done that and pressed ok but the display still stays the same 😥
And as for the weather the sun came out 😂😂🤣
Post #449979 5th Sep 2017 4:50pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi, change the clock to 24hr format, that will show correct format of date.
Its in the audio system manual. Thumbs Up
Post #450007 6th Sep 2017 6:37am
Simran0211
Hi gregdav I have also tried that aswell but to no avail
Post #450051 6th Sep 2017 2:59pm
robanzac
New Zealand
Simran0211
I have exactly the same problem in my 03 Vogue i.e date in US format.
Even though all the options are there to be seen and selected in the settings screen they simply will not change.
And it's not just the date either, it's everything.
Can't change clock to 24h format
Can't change Km to Miles
Can't change L/100Km to MPG
None of the above actually effect me as I am in a metric country, but it would be nice to know why the settings are "stuck" as they are. Rob
Post #477801 9th May 2018 12:52am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Its possible your instrument cluster may have been changed at some point. Try looking at what option 10 in the hidden instrument pack menu is (check the wiki) to see if its a metric or imperial country setup on the pack Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #477864 9th May 2018 7:22pm
robanzac
New Zealand
nicksaab,
You are exactly right.
My option 10 reads LAND: 02 US
I suppose changing that isn't an easy thing to do? Rob
Post #479747 31st May 2018 5:36am
nicksaab
Its possible that the IID tool might reprogramme it, failing that possibly dealer software? Current Fleet:-
Post #479752 31st May 2018 7:36am
Miserable Old Codger
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi Nicksaab,
I am very new to this site and I really am an Old Codger ( Not always Miserable) a 7 year old knows more about computers and programming than I will ever know. Early 2017 I imported my 322 from Japan and have recently been playing around with the binnacle/speedo to change the speedo dial display. I am no expert but have picked up a few things about them. For instance the part number of UK binnacles is YAC 501230 and the speedo dial has main MPH and inner KPH. My Japanese binnacle is part YAC501220 and has KPH dial only. I can definitely say that they both have date formatting, temp (C or F) formatting and gallons/Litres format.
There is another binnacle with part number YAC 501210 this has main MPH and inner KPH I guess this is put on the USA exports and is the one in yours ( Your code 10 shows 02 US )
The strange thing is that if yours is US model it would have the date format as shown on yours but temp in F and miles in Gallons because that what is mainly used in USA.So it must be interchangeable. Yours does not so if you can't change it then there must be a fault.
A word of caution!!! If your RR is a USA model and you change from litres to gallons then your MPG will be different because US gallons are about .2 more than an imperial gallon. Not sure if that can be programmed, probably not or they would not need separate part numbers.
As a side issue imperial gallons are based on the weight of 10 lbs of water and US gallons weight of dry grain.
Post #479757 31st May 2018 9:03am
Correction UK Binnacle YAC 501220 and Japanese YAC 501230.. Not just old but obviously now the mind can't get things right first time... Well I suppose there are sometimes advantages having to do things twice to get them right....
Post #479758 31st May 2018 9:12am
p38arover
Australia
The other way around - the Imperial gallon is 20% larger than a US gallon. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #479765 31st May 2018 10:25am
p38arover,
Hi, yes of course you are right, I lived in USA for 4 years and knew that. But did you not read I have to do everything twice to get it right once http://www.fullfatrr.com/forum/images/smiles/icon_lol.gif
Post #479766 31st May 2018 10:35am
See, see, I can't even do that first time, I tried to get a smile in there but only got the link ...
Post #479767 31st May 2018 10:39am
