Home > Maintenance & Mods (L322) > Ignition problem
Mart67
2005 Range Rover Supercharged 4.2 SC V8 Java Black
Ignition problem
Morning all,
I have an issue looming with my ignition switch I think.
It's only done it a couple of times but turned the key this morning and nothing?? Tried the key in the on odff switch a few times and she started up.
I checked the battery and that was fine as initially I thought the battery was flat and that's why it wouldn't start.
Looking online it appears common?? Does anyone have details of what part needs changing as I don't want to get caught short!!
Post #449877 4th Sep 2017 9:28am
Weegie
Looks like your switch is on the way out. Repacement switch is approx £99 IIRC. Do a search on "igntion switch" Best replace it before it packs in completely . As I know to my cost. Crying or Very sad John
GAP iiD BT-Sold
Post #449879 4th Sep 2017 10:24am
Mart67
All sorted, £48 from Duckworths!!
Post #450881 14th Sep 2017 8:21am
standupking36
was it easy to replace?
Post #450938 14th Sep 2017 9:01pm
It's not hard, no special tools required, just download Rave from the WIKI, take your time and take pictures as you go.. Thumbs Up Pete
Post #451019 15th Sep 2017 4:59pm
standupking36
did it come made to your key? or do you get a new blade?
Post #451210 17th Sep 2017 8:15pm
The switch is separate to the ignition barrel, it's the switch below the barrel that fails so you keep your old key.... Pete
Post #451216 17th Sep 2017 9:21pm
standupking36
oh ok pete thanks, so with it being notchy, its not actually the key part??
Post #451219 17th Sep 2017 9:28pm
Mart67
Easy change, 1hr max, all you need is a set of torx bits. I only changed the actual switch side of the barrel not the barrel itself.
Post #451552 21st Sep 2017 2:55am
