![]() | Home > Technical (L322) > 3.6 tdv8 coolant leak |
PUPPYDOGS Member Since: 11 Nov 2013 Location: leeds Posts: 10 ![]() ![]() ![]() |
HELP PLEASE 3.6 TDV8 2006
Thank you. I have decided the best course of action might be a coolant pressure test first. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
I had a similar leak, turned out to be a pipe that runs in the V of the engine - front to back - got it sorted eventually but it was a few quid for parts and a few hundred quid for labour. Mind you mines petrol so yours may be different, well you certainly wont need to remove the supercharger |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Feel down the small hose from the bottom of the header tank, it has a tendency to rub and wear through.
Thank you.
