Home > Technical (L322) > Front bumper removal ?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
Checked in wiki but couldnt see a how too , so how do you remove front bumper , need to fit a new parking sensor
Post #448975 24th Aug 2017 6:37pm
i used the search function pal and found this,
http://www.fullfatrr.com/forum/topic9699.h...ont+bumper ... - .- -.
Post #448986 24th Aug 2017 7:24pm
@ bembo449
Have you accessed this yet: (RAVE Manual)
https://docs.google.com/uc?id=0Byv5LFgQZql...t=download
Should save you a lot of time questioning and searching..... .
Post #448993 24th Aug 2017 8:12pm
bembo449
will download it pal but if we don't ask questions how do we interact with each other ? Wink
Post #449003 24th Aug 2017 9:04pm
you'll find that the regular members that are on the forum most days might not respond to common questions that can be found easily in the wiki or using the search function , so your question might not be answered pal... ... - .- -.
Post #449029 25th Aug 2017 7:34am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Iirc, powerful uk do a face lift video on you tube.
it shows front bumper removal pal.
Post #449032 25th Aug 2017 7:54am
Dolphinboy
Depending on which sensor u r removing, you don't necessarily need to remove the bumper. If it is the end ones, you can replace in situ (long arms and small hands help!)
Post #449042 25th Aug 2017 9:51am
bembo449
Sorted it this aft , turned out to be damaged wiring , but of soldering and they are fully operational again , thanks to whoever suggested the wiring maybe at fault
Post #449079 25th Aug 2017 3:59pm
