![]() | Home > In Car Electronics (L322) > Shocking standard stereo |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 299 ![]() ![]() ![]() |
😡unreliable piece of |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
Wunt blame you pal , thow it does make you wonder why its so poor |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Don't know why your sound system is so poor pal.
+15 years and all original kit still going strong, loud enough and clear enough. Radio/Tape/CD/TV and video (in motion, for passengers) if I want it, and original SatNav still fine.
cleaning everything up ?? can you be more specific please pal |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7879 ![]() ![]() ![]() |
They are prone to damp and leaks in the rear left cubby where the amp, sat nav and tv etc are. The connector plugs and pins can get damp and corroded. Unplug each plug on the units, one by one, with the car turned off and dry them out or use switch cleaner etc.....
Ah i see ok pal , the dvd player is missing so i presume that wont affect it ?? |
Never had a DVD player fitted from factory so I hope it's not that being wired in that's done it. Though you could technically have one fitted as factory as part of the Autobiography options, with the screens in the front seat backrests.....
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1550 ![]() ![]() |
My Vogue's system is excellent. Ron B. VK2OTC
right folks , looking to test the system from the AMP this aft , what setting do I need to use on my multi meter ? |
I don't know what you are intending to test with a multimeter.
hmm but surely there is a way to test the amp and see if its functioning pal ? |
Yes, but I'd use my audio oscillator and oscilloscope for starters.
ok , so if I get readings for them on every pin from the amp , does that not suggest its functioning properly ? |
