![]() | Home > Maintenance & Mods (L322) > TD6 intermittent misfire / bad tick over resolved |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
I have had a very intermittent problem brought on by hard acceleration only. Normal driving gave no issues. After spirited driving the tick over sometimes became a little lumpy but cleared after 10 mins or so. This has been going on for a long time as I could not find anyone else reporting similar. I have had a laptop at the ready with IPNA installed to monitor the engine when the symptoms arouse. After a few episodes I could see injector 6 values increased coinciding with the lumpy idle.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35511 ![]() ![]() |
sorted |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 ![]() ![]() ![]() |
cool , glad you posted up that you solved it pal |
Due to my issue being intermittent and only surfacing after plenty of wellie lasting only for 10 mins or so I now believe it was an electrical fault with the injector. I had in fact taken out No 6 a few months back and removed the needle and nozzle and checked the spray pattern was ok and not blocked. Anyway a few days down the track and its 100% cured the problem. 2007 TDV8 VSE
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 ![]() ![]() ![]() |
electrical problem on injectors I had an issue and replaced the injector loom with Genuine part , they were actually cheaper here in Australia $80 than getting one from the UK at $200! m after replacing loom i was able to drive up steep hills at 80kph without it bogging down. |
