![]() | Home > Off Topic - Other Cars > Any one know of a 6 speed transmission for 4.6 Thor? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1469 ![]() ![]() |
Not seem one done ... but that doesn't mean it cant be done though. RRPhil would be better to talk over the differences. I think the 6hp26 is quite a bit smaller than ZF4 speeds ... so you would need to be looking at both adapting the plate joins AND the lengths of shafts compared to existing known combinations.
GenevaRR Member Since: 28 Apr 2013 Location: Oundle Posts: 11 ![]() ![]() ![]() |
Thanks I will look up the compushift
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3201 ![]() ![]() ![]() |
I wouldn't imagine it would be particularly driveable tbh.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
There isn't a simple six-speed solution because they're all electronically controlled. On the basis that you can buy a GM 4L80/Rover V8 adapter, the 6L80 should also work, but you'd need an aftermarket controller. Lot of effort (and you'd be much better off just sticking in a matching LS with it at the same time).
