Home > In Car Electronics (L322) > Surround cameras
j_rov
Surround cameras
So, I have the dreaded blue screen on a 3 of my cameras. With a bit of fiddling, I plugged them one by one into the rear-camera booster and they all worked fine, except one, which i will presume dead.
So, the question is, is there an aftermarket booster for the other cameras like the rear one uses?
Cheers __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #448669 22nd Aug 2017 11:40am
why not replace the dead camera? ... - .- -.
Post #448686 22nd Aug 2017 12:17pm
j_rov
i will, but need the other 2 to work too. __
Land Rover History:
1976 Series 3 2.25
Post #448694 22nd Aug 2017 1:03pm
but you say they all worked except for one...replace that dodgy one and they will all work ... ... - .- -.
Post #448697 22nd Aug 2017 1:11pm
j_rov
Poor wording, sorry.
I have 5 cameras, 2 show a picture, 3 do not. I have connected the 3 that do not work to the rear camera booster in turn. 2 of them show a picture, 1 does not.
So, 4 cameras actually work, but only 2 show a picture. I need 1 new camera, and a way to get the 2 that do not show a picture to be boosted so they do. I have followed the LR guide of reducing bends etc already. __
Land Rover History:
1976 Series 3 2.25
Post #448698 22nd Aug 2017 1:27pm
its possible that the dodgy one is stopping the others from working, like being wired in series type of thing...i'm sure i read that on the forum somewhere..
edit,
http://www.fullfatrr.com/forum/topic38221....nd+cameras ... - .- -.
Post #448700 22nd Aug 2017 1:38pm
j_rov
Makes sense i suppose. I might pull it apart and swap left and right to see what happens.
I noted on the wing mirror ones there was no part number which i found odd (had to take apart to re-attach lens). Has anyone got a list somewhere of these part numbers? My favourite Russian parts catalog doesnt list them.
Cheers __
Land Rover History:
1976 Series 3 2.25
Post #448716 22nd Aug 2017 4:00pm
PN is there ..
Post #448722 22nd Aug 2017 4:45pm
j_rov
Thanks __
Land Rover History:
1976 Series 3 2.25
Post #448723 22nd Aug 2017 4:56pm
GGDR
I had one blue screen (door mirror) took it back to the dealer who found a loose cable/connector.
So worth a juggle or two throughout your system.
That said, in researching mine I found that LR upgraded the cable so if your problems are persistent it could be this. The new cable has less bends too I think.
. Cheers, Greg
Post #448744 22nd Aug 2017 7:11pm
