Home > Technical (L322) > TDV8 turbo replacement engine in CAR.
stu
Well, just to add my two penneth worth, I've had all versions of the L322 and never had a turbo problem. My second turbo got a good workout today dragging my Buccaneer through Gods own county of Yorkshire...😂
My 3.6 was tuned, so running more boost pressure and it was faultless.
Turbos just don't fail every day of the week, it's like everything else mechanical, it's unlucky if it happens to you Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #448592 21st Aug 2017 6:39pm
Mikey
CS wrote:
Surely that should be peh? Laughing
Pretending I'm posh Whistle
At least I'm posh enough not to put it on a roll Thumbs Up
Post #448613 21st Aug 2017 8:17pm
MartinM
Norway
Like your last sentence....one gets a little bit paranoid reading all the threads and some of the response. According to statistics my current P38 V8 should have brown up by now.....still works Surprised
Post #448619 21st Aug 2017 9:02pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
I must be very unlucky then! The Td6 turbo failed in February and the one on my 520d went a couple of weeks ago.
Post #448630 21st Aug 2017 10:49pm
stu
GDM..
you are unlucky truly!! Mind you I always let my turbos warm up and run down, comes from the days when I was on crazy jap cars kicking out too much horse power and would never have dreamt of owning a diesel car.. Shocked
Martin...
What can I say! P38 are terrible for reliability, especially electrics, but if you've got one that works keep it!! Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #448659 22nd Aug 2017 10:20am
GerryF
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Stornoway Grey
Sorry Mickey but can I just check if you mean left from inside the car or left when looking at the engine from outside the car. Tks in advance from a person with a noisey turbo on the offside of car - left when looking at the engine bay from the front! 😜
Mikey wrote:
Engine stays in the car, sort of Whistle
Right hand turbo can be done in a few hours
LH turbo needs:
Exhaust manifold off
Engine mount bracket off
Diff off
Engine mount off
Subframe off
Steering rack off
That said, I have done them at the side of the road, so nothing hugely difficult. Just fiddly and time consuming Thumbs Up
Post #616791 18th Dec 2021 12:11am
