Home > Technical (L322) > BT iid tool help
Baltic Blue
BT iid tool help
I am new to this little tool and really struggling.
Are the fault codes shown in the following screenshot normal?
I can't clear them and am so scared of doing something wrong I am starting to wonder if I should leave well alone.
What I really want is a set of reference screenshots showing me the normal state while I know the car is "fault free "
Any tips to get me more confident and help me learn would be really appreciated.
Thanks.
Also I have connected my CTEK via the towing socket as I do regularly to keep the battery topped up but I am still getting the "low battery please start engine" message even though it is reading 12.8v ?? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443601 5th Jul 2017 10:04am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
your not on your own their
Post #443603 5th Jul 2017 10:11am
Baltic Blue
I give up !!!
The ignition shut down and the voltage across the charger has gone up to 13.4v.
I have left it on charge but am confident it will be fully charged because I have done 4 journeys over 60 miles this week.
It always does this if I sit listening to the radio with the ignition on ?? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443605 5th Jul 2017 10:35am
Baltic Blue
Is this normal or have I got a problem? Or do ther users sit with the engine running whilst using the iid? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443635 5th Jul 2017 1:23pm
i always have the engine running when playing with my tool.....and as for the errors you have, if every thing is working ok then dont worry about it.... ... - .- -.
Post #443636 5th Jul 2017 1:24pm
Mr Tee
Dirty bastard Stan
Post #443644 5th Jul 2017 2:09pm
didn't take long Rolling Eyes Laughing ... - .- -.
Post #443647 5th Jul 2017 2:21pm
Giantlandyman
United Kingdom 2012 Range Rover Autobiography TDV8 Santorini Black
You can ignore P040 (D) because all that is the temperature sensor on the passenger side manifold logging a fault because the temperature measured is greater than that which the sensor was designed to measure.....very common on 4.4 TDV8.
And I always have the engine running when the IID is attached.
Post #443656 5th Jul 2017 4:09pm
Baltic Blue
Thanks,
I will run the engine when I try again tomorrow, obviously putting the charger on doesn't work for some reason.
The iid was showing 12.2v but a voltmeter across the charger was 13.4v ?? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #443658 5th Jul 2017 4:55pm
knares
how did you go, did you sort it
Post #447565 12th Aug 2017 1:01am
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
that must be an echo from bmw , all the 7 series BM's ive had bong if you so much as think about having something electrical on without the engine running , overly sensitive imo but I suppose its better than looking a tit havin gto jump start one of these luxury vehicles Razz Twisted Evil Embarassed
Post #447568 12th Aug 2017 4:28am
stu
A bit late to the party really, but playing with your Tool is the answer!! Ask Stan.. Whistle
As stated always have the engine running and be brave! When I first started using mine, I lit the dash up like Blackpool Illuminations!
Remember when you first set it up it takes note of your settings, so you can reset to default if you like. Just switch it on press clear and then read the faults again. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #447589 12th Aug 2017 10:12am
