Home > Maintenance & Mods (L322) > Replace M62 Engine? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
oh poo, never have guessed!
5th Jan 2011 4:56pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Right. Let's say I spend £3k on the engine, maybe even have the gearbox rebuilt in the next year or so. Spend = £15k, but have a car with good as new gearbox and engine. Spend an extra £2k on front facelift (already has rear leds), £1k on rear screens and reversing camera, total £18k.
5th Jan 2011 5:24pm |
True, but is there really much difference between on 02 and an 06 in that respect? Bushes, airbags etc?
5th Jan 2011 7:20pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
what is actually wrong with the engine and how did it come about to getting the fault ? onto no6 Range Rover
5th Jan 2011 7:58pm |
Good question and one to which I wish I could provide a good answer. However I don't really know, basically it's noisy, sounds like a combination of vanos problems and hydraulic lifters. Range Rover-less at the moment - Pining! |
5th Jan 2011 8:10pm |
letsavit2 Member Since: 16 Oct 2010 Location: essex Posts: 854 |
i thought the bmw v8 was a solid engine, sure its not your lpg system, can you bypass it to test? 2004 black Vogue TD6 |
5th Jan 2011 10:03pm |
have you had it checked by anyone in the know to determine if it is as you say or is it just guess work because it sounds rough ? as engines can sound truly shockingly worse than they are through various faults that occur onto no6 Range Rover
6th Jan 2011 8:10pm |
Made progress today. Firstly, I've found a chap called Stuart Ambrose, who's a Land Rover enthusiast, who's also a mechanic, who's turned his hobby into a business. He rebuilds and fixes many V8's, and operates a mobile service as well as having his own workshop. He's going to come and give the car a good going over, compression test, leakdown test etc etc. And have a damn good listen with his stethoscope.
6th Jan 2011 8:21pm |
