Home > Technical (L322) > HELP!! I need to open bonnet
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
I broke my bonnet cable at the lever luckily I managed to open the bonnet as the cable had snapped at the lever, so pulling it with pliers opened the bonnet, all was good, I disconnected the cable joiner in the engine bay and feed the new cable through, all was good.
I went back into the cabin to feed that blastard grommet through the fire wall, whilst I was doing this the bloody wind caught the bonnet and slammed it shut.
so guess what! Now I can't open the bonnet. Any idea on how I can't get the bonnet open now?
Post #447315 10th Aug 2017 3:00am
dingg1
if your cable is connected to the bonnet latches (unclear if you managed to do this)
you may be able to get a wire coat hanger and be able to latch onto the cable and manage that way
good luck
Post #447320 10th Aug 2017 6:56am
lounge_on_wheels
Ok To clarify, the main cable from the bonnet catches is still there,
I disconnected the short pull cable that comes from the lever at the point where it connects to the main cable.
So the bonnet is shut, the main cable from the bonnet catches is still there underneath the closed bonnet.
Hopefully there is some way to access the end of it.
I did a google and there was a post on accessing it from the drivers side wheel arch after the inner wheel arch panels were removed and hopefully reaching up to grab it?
Post #447322 10th Aug 2017 7:21am
someone here recently had to smash the grill to get access to the hinge locks, maybe this is the way to go.. ... - .- -.
Post #447324 10th Aug 2017 7:29am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I had a problem with one of the catches and managed to pull out the front of the passenger side wheel liner and put a medium sized lever bar up to the back of the catch and release it that way. I'm fairly sure you could do that to the driver's side too. I had another catch knocking about so could see where I had to lever - which helped. Current:
- 2017 L405 3.0 V6 Autobiography
- 2013 L405 4.4 TDV8 Vogue [For Sale]
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #447332 10th Aug 2017 9:07am
lounge_on_wheels
I wish I had a picture of how the cable lays along the top of the inner fender, so when I pull the inner guard off I know roughly what I am feeling for with my hand. Any one willing to take a pic for me it would be greatly appreciated.
Post #447338 10th Aug 2017 9:18am
Reaching the cable alongside the wing with the inner wheel arch removed is a bit of a non-starter, the cable is laid in the 20mm gap between the wing and the large electrical box.
However if you remove the offside inner wheel arch you get reasonably good access to the cable under the slam panel next to the offside bonnet catch. You will need to reach up past the intake air flexible duct or use a hook to try and pull the cable down so that you can operate the unconnected loose end. Hopefully you didn't get round to securing the cable anywhere.
Post #447352 10th Aug 2017 11:36am
lounge_on_wheels
Hi Nicedayfor it, I hadn't touched the long cable, only undid the short cable from it , and un-clipped the plastic cover that covers the 2 cable joins, all the rest of the long cable is attached as per factory. so it might prove difficult, either way I have no choice but to try it , as I want to avoid breaking the grille.
Post #447457 11th Aug 2017 1:35am
lounge_on_wheels
Nicedayforit, your a champ, I pulled the inner wheel arch trim off and put my arm up near the intake pipe and pulled on the cable and the bonnet popped open, thanks mate your a life saver. Very Happy Very Happy Very Happy Very Happy
Wheel arch inner guard plastic panel removed.
Reach up here.
This is the cable you grab, pic taken from top when bonnet was open, it sits behind the top rear of the headlight.
Pulling this will open the bonnet, that's assuming you haven't snapped it at the latch end.
Post #447458 11th Aug 2017 2:47am
Glad to be of help Thumbs Up Very Happy
Good to know it worked relatively easily. Will be handy for the future, I doubt you will be the only one to find themselves in this situation.
Post #447465 11th Aug 2017 8:05am
