Home > Technical (L322) > TD6 engine shake after power off |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 803 |
so then engine shudders after you switch the key off , yes ? OR does it actually carry on running and then stops ?
9th Aug 2017 3:02pm |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 182 |
thanks for your quick reply!
9th Aug 2017 3:22pm |
I take it the car performs as it should , no loss of power , strange noises or transmission problems ? |
9th Aug 2017 3:26pm |
everything fine, had it since i bought the car, gearbox was changed last week and now i wan't to get rid of
9th Aug 2017 3:33pm |
you can take it off and see if it makes any difference but I doubt that's the issue |
9th Aug 2017 3:56pm |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
I would try injector cleaner as it sounds like the injectors are 'lazy' or slow at closing - only a quick thought |
9th Aug 2017 6:28pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
As above, or maybe check your vacuum tubes for the engine mounts, maybe a split in a tube.
9th Aug 2017 6:41pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
+1 on the injector cleaner. I use this stuff sometimes when I have that issue (haven't had it in ages).
9th Aug 2017 8:08pm |
i will try the cleaner and report!
9th Aug 2017 8:24pm |
Cleaner helped, after a while shaking was getting better till it was gone. But i noticed another thing that i fixed, the crankcase breather filter. it was full of oil! car is still a little smoky on the test drive, i think it will get better! maybe i give it another cleaner. thank you for the input! |
17th Aug 2017 5:16pm |
Is the crankcase breather the one on top at the back of the engine ? If so there is a BMW 'upgrade' one - it is no longer a paper/cotton filter but a plastic vortex type - fit and forget. Someone should be along with the details shortly |
17th Aug 2017 9:18pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
clemenz,
18th Aug 2017 9:22am |
On my TD6 (155k)and both my Volvo D5's ( one at 145k and the other at 237k)I use 2 stroke oil - have done for years - creates a cleaner burn and less emissions and also lubricates the injectors and fuel pumps. In the UK the diesel has a high amount of bio-diesel added by the manufacturers and as such provides less lubricant for the afore mentioned parts/components. I have never had a fuel pump failure (a lot of taxi drivers in the UK did with the introduction of bio-diesel being added - just google it) , car runs smoother , sound less of a tractor and also ticks over quieter. People have reported more power and more mpg but can't say I have noticed.MOT emissions show that since I started using it the readings are very very low. Just use ordinary 2 stroke oil and not semi or fully synthetic though , and low ash. |
19th Aug 2017 7:53am |
I will bring up my old thread and answer myself
23rd Oct 2019 10:00pm |
