![]() | Home > General (L405) > Comfort (or not) |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 ![]() ![]() ![]() |
There's some slight variation in seats across the range - however, I find them generally quite comfortable and I guess you get used to them.
Ailamod Member Since: 25 Jul 2017 Location: Scotland Posts: 7 ![]() ![]() |
This one also had 22s and that hadn't occurred to me as it wouldn't have helped.
The wheels do make quite a dit of difference, but I'm mostly on motorways so I went for style over comfort |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
I run a late Disco 4 HSE Luxury and found that the seat squab on the Vogue that I took out on test drive was less comfortable than that in the D4, while the VSE and AB were a big improvement. It seemed both softer and more supportive, with a better shape and there was more adjustment - particularly being able to move the seat squab back and forth independently of the rest of the seat - loved that!
That's a good shout, will see if I can get a hold of a SE but think the AB might be well out of my price range.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
My mates got a 16 vogue and I said before it's a lot harder then my 12se seats I hope the se and ab are better as an evoke feel seat is not for me either. _____________________________________________________
emilio Member Since: 27 May 2015 Location: Malta Posts: 58 ![]() ![]() ![]() |
done the 1500mile trip from the uk to malta in under 18 hours twice, once in a bmw and another in a 2012 rover. with the bmw my legs were jelly could barely walk, with the rover i was ok could have turned round straight away and do again. |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Alistair is right about the wheels. It's a horses for courses sort of thing. For me I want the wheels to look good on the car but have a compliant ride and 21's give me that compromise. The seats are okay but I've only ever had Vogue SE's and Autobiographies and the seats IMHO could be comfier, especially around the tail bone area. |
Surprisingly, a 22" wheel Range Rover gives a better ride than a 20" wheel Disco 4, itself no slouch in the ride quality stakes |
Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139 ![]() ![]() |
Weren't sat on your house keys were you ?Seriously though i have been in a few rangeys and found the seats to be less comfortable than that of my present sc and previous xjr. Full fat 4.2 Sc
Appreciate it's a bit subjective but I owned a D4 HSE Lux with 20's and went straight from that to an L405 AB with 22's and found the full fat less forgiving than the D4. Better turn in and certainly more dynamic but not quite as cosseting. Since then I've owned several more full fats with 21's and would suggest that they ride about as well as the D4 with 20's. 2016 SDV8 Autobiography And several others previously. |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1390 ![]() ![]() ![]() |
I can't comment on how the 405 compares with the S Class, but do think that seat adjustment makes quite a difference. If you are getting a sore bottom you might need to raise the front of the seat a bit and tilt the back further, so that the weight is spread more. I thought my 2012 car was less comfortable than the 2004 one, to some extent I think that is caused by there being the seat ventilation kit, which presumably reduces the padding, but adjustment made a big difference. I would not expect discomfort after 200 miles. The SE and AB seats have semi-aniline leather and are softer, plus there are differences in the adjustment range of the different seat types, it might be worth checking which type is in cars you are considering.
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Mine is like sitting in a stately home! Very comfortable 2010 defender utility
Interesting finding. You have a lot more experience of driving L405's than I have, so you must have a point. I was surprised when, having driven a 2017 22" V8 AB over a 15 mile test route, I drove home exactly the same way in the HSE Luxury and felt all sorts of surface imperfections that I never noticed in the RR AB. Could the 2017 car have had a subtle suspension change? |
