Home > Technical (L322) > 2010 Range Rover vogue tdv8 keeps going in to limp mode
Rob199027
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi there
Just bought me Range Rover at weekend and when you really kick it down full throttle from about 10-20mph the car goes into limp mode says restricted power and gearbox fault etc when I bought the car the battery was flat we jumped it and drove it and was fine just reading a few threads over the net says it could be sign off battery on way out ??
Any help be great Thumbs Up [/list]
Post #446839 6th Aug 2017 4:38pm
3.6?
Top turbo hoses
Cheap and easy
http://www.fullfatrr.com/forum/topic26843.html
And the one the other side.
All that needed to whip it off to check is a screwdriver.
But also they don't like flat batteries, so put that on charge. Have a read on here about alternators etc and check your voltages There is nothing that can't be fixed with a hammer😜😜
Post #446843 6th Aug 2017 4:52pm
Rob199027
Ok lovely will have a nose see what's going on
Cheers
Post #446847 6th Aug 2017 5:12pm
If split it's most likely will be under the webbing on the right hand hose so have a look at that one first. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #446851 6th Aug 2017 5:38pm
Rob199027
Update on limp mode problem fault coming up as fuel pressure problem Mad hopefully just a fuel filter ?? Any other problems leading to this anymore advice be great Thumbs Up
Post #447189 9th Aug 2017 8:50am
Mcfly309
Eyup Rob,
Had similar on mine last month. Hoses were fine but the inlet manifold was split along an inner seam.
Restricted Performance when accelerating hard, and diagnostics showed fuel filter and various MAP/MAF sensor faults.
£420-ish for new manifold including 4 x hoses, plus 2 hours labour at the best independent around here, Maltings Off Road.
Hope this helps.
Post #447205 9th Aug 2017 10:44am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I think Rob has the 3.6 not the 4.4.
Post #447227 9th Aug 2017 2:38pm
Rob199027
Hi everyone
Yep mine 3.6 ! And got it back from garage today had a service plus new diesel filter they run checks on all injectors etc and everything was fine, they tested and hopefully everything is ok now cleared fault codes and seems to be all good Thumbs Up till the next problem but oww well wouldn't drive anything else
Post #447252 9th Aug 2017 5:52pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
the freelander derv units don't like having dirty fuel filters , I change them at every service on the 3 customers I have that own one , soon drop into to limp home if the filter is past it
Post #447257 9th Aug 2017 6:09pm
