Home > In Car Electronics (L322) > CD,s won't load
markyp
England 2004 Range Rover Vogue Td6 Zambezi Silver
CD,s won't load
Anyone got any ideas ? The magazine has got discs in but the display says no disc inserted, when I put the magazine in the CD player the disc,s seem to click instead of loading, Thanks , markyp. 2004 vogue
1978 Pontiac Firebird
2010 Fiesta
Post #413503 14th Nov 2016 12:16pm
miggit
Whistle One of these may help Wink
Rolling with laughter Rolling with laughter
But a slightly more serious note, It doesn't sound too good for your CD player Sad
There are a few things you do... Firstly you need to know which system you have, I will assume that you have the non touch screen Sat Nav.. So if you want to play CD's then a S/H replacement would be the easiest way round the problem.
However if you have an iPod then a CD emulator could be a better option, these replace the CD player and will give you either an aux audio connection and / or an iPod connection with / without steering wheel control.. These units start around �30 and climb in price according to the level of control they allow you Thumbs Up
If your system is touch screen then I'm afraid that a S/H CD might prove a bit more expensive to cop hold of as the list of donors is a lot smaller, and the Emulator iPod connection is even smaller Sad Yesterday I couldn't spell Engineer... Today I are one!
Post #413511 14th Nov 2016 1:04pm
Clivefog
Take cassette out remove all CDs bar one, replace and see if it finds the one.
If that works reload all CDs and try again.
May need to power off head unit and reselect CD.
Having 6 slots showing is a positive, just clicking could be athe cassette or CD unit having a worn cog or two on the draw in process.
Best of luck.
Post #413560 14th Nov 2016 5:00pm
markyp
Thankyou Gentlemen, I will have a look at the weekend 👍👍 2004 vogue
2010 Fiesta
Post #413601 14th Nov 2016 8:10pm
Jacckk
2010 Range Rover Autobiography 5.0 SC V8 Mariana Black
I had a similar thing with mine recently.
When you put the magazine in it should go through each of the CDs and load them in then spin them to check the disc. Does yours do that?
Mine didn't do anything when putting the magazine in. I took the CD changer out, removed the lid and lubricated the mechanism. Works perfectly now!
Post #413632 14th Nov 2016 10:04pm
mgdenison
United Kingdom 2002 Range Rover HSE Td6 Santorini Black
Are these easy to remove to inspect?
Mine is saying no cassette / magazine (cant remember which one) even when it is in with cd's loaded. Also seem to keep blowing the 5amp fuse?
Post #447113 8th Aug 2017 7:00pm
Topbrass
England 2005 Range Rover Vogue Td6 Zambezi Silver
I had same problem, wouldn't load CDs so spayed cartridge with wd40 (lightly)
Slapped my best of Val doonican cd in ............sorted .
Post #447137 8th Aug 2017 7:58pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Changed mine out a few days ago, for a second hand unit off the bay.
works a treat now, Daniel o'donnal belting out. Shocked
Rolling with laughter Thumbs Up
Post #447172 9th Aug 2017 5:34am
