Home > Technical (L322) > Passenger Door Electrics and Locking issues
mgdenison
United Kingdom 2002 Range Rover HSE Td6 Santorini Black
mr_spock wrote:
You may have 2 issues.
The central locking and mirrors will fail if the door latch dies. I've replaced one front and one rear, and both times had those symptoms. When the latch fails the car doesn't know if it's locked or not, so throws up its hands and gives up.
Latch is an easy peasy replacement. You do NOT have to replace the lock.
Window could just be a mucky switch.
Window operates so may investigate the latch. Seen a couple on eBay that are reasonable price and quoted as fully operational
Post #447111 8th Aug 2017 6:57pm
mgdenison
Also concerned that one of these is not connected anywhere. 1 appears to be the speaker wire (blue connector) but not found where the other goes...
Post #447112 8th Aug 2017 6:58pm
