Home > Technical (L322) > Air Suspension Inactive?
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Guys
If the message "Air Suspension Inactive" is displayed on the dash is it safe to drive the car to a place to have it repaired?
As I understand things the car will remain at drive height until the problem is rectified?
Jim
Post #447082 8th Aug 2017 5:33pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Wouldn't recommend long distances as I'm guessing you don't know what the fault is, but to drive to have it looked at / repaired will be fine.
Could be anything from a faulty height sensor, which obviously no harm will be caused to a leaking air bag, in which case the compressor will be constantly working to keep it at height and wear the compressor quicker
Is the height adjustment panel on the dash still lit, with the hold button lit or have they all gone out?
Post #447083 8th Aug 2017 5:42pm
As you and Stacker say Jim, it all depends on the state of the suspension.
If you get ASU bong and ride height stays where it is, you should be good to go
(if away from home and you get ASU, and you have an IIDTool or similar, read the faults but do not reset/clear, as you may well find yourself on the bump stops, with a long way to get home!)
If you get ASU bong and you are on the bump stops, take it easy, short trips, slowly, avoiding bumps and potholes. .
Post #447157 8th Aug 2017 9:37pm
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
as I found out this morning , its virtually undrivable if on the bump stops Shocked
Post #447213 9th Aug 2017 11:59am
