Home > Technical (L322) > Passenger Door Electrics and Locking issues |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 |
Is everything else working on the drivers window switch pack? |
14th Jul 2017 7:05pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Have you had a look at the connectors (between the door and the body), it is either somewhere in the A pillar or in the door that shuts onto it. There is a post on here somewhere about this where the car would not unlock and mechanics got access by "removing" the side vent and accessing the connectors which were a bit worse for wear. Cleaned up / repaired and all fixed.
14th Jul 2017 10:27pm |
mgdenison Member Since: 01 Jul 2017 Location: England Posts: 13 |
Yes all the rest of the switches work on the drivers door. |
15th Jul 2017 5:19am |
Which fuse is blowing? .
15th Jul 2017 8:52am |
Fuse number 8 |
15th Jul 2017 3:50pm |
As you say that is for the on board computer, audio system and telephone (where fitted)
15th Jul 2017 8:39pm |
UPDATE...
21st Jul 2017 10:05am |
Check out the powerful uk video on removing a door card, should indicate where everything goes:
21st Jul 2017 10:55am |
Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248 |
Had a similar (no interior lights or central locking) problem with mine - took it to a local vehicle electrician who charged £40 to sort it. QUID FACIUM TIBI
24th Jul 2017 8:00pm |
Found out today that the passenger electric window is always live regardless of the ignition been on or off.
7th Aug 2017 4:24pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1247 |
New door lock is going to cost a fair whack, we had to have our drivers side door lock replaced recently and it was over £200 plus it took about 3 weeks to arrive as it had to be coded to the key from LR. Might be cheaper on the passenger side though! |
7th Aug 2017 5:50pm |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 |
You may have 2 issues.
7th Aug 2017 9:00pm |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 |
I had this problem on my front passenger door as well. It was a wiring problem which an indy garage fixed for me. They removed the lower front wing panel below the side vent, the side vent itself and the rubber plug/socket at the A pillar. Water or moisture had got in to it and corroded one of the pins to dust. They replaced this pin and cleaned up the rest of the contacts and all the door electrics sprang into life. It also cured the non functioning passenger mirror (adjustment and power fold) and the odd one of old being able to operate the passenger window from the passenger switch. Hope this may help. |
8th Aug 2017 11:14am |
Thanks. Looks like if its fine tomorrow the panel is coming off. It's starting to bug me now.
8th Aug 2017 6:56pm |
