Home > Maintenance & Mods (L322) > Gearbox additive
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Gearbox additive
Put two tubes of the gear shudder in the box today as have been told by a few box people it's a great teflon coating to stop and prevent shudder and give smoother changes and WOW trust me it's amazing so smooth on changing and I know a chap who had a slight judder at about 1500 rpm and cured his 8 months ago,it's worth a go I put in box with the plug on the side not the bottom one, leave on tickover though and take plug out or it will pour out if not running ,done 20 odd miles up and down hills and smooth as silk 👍 It's called Dr tranny lube in the red tubes lol on fleabay 😉 _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #446566 3rd Aug 2017 8:24pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
I think I might want to give this a go on mine...this is compaible with a 2008 HSE 4.4 right?
Can you clear this part up a bit...I'm a little confused
If you get a chance can you post a pic of the plug you removed/put this in? I've never worked on the tranny of these let alone looked at them. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #446568 3rd Aug 2017 8:53pm
Mikey
The judder will come back... It's not a magic fix Thumbs Up
Post #446573 3rd Aug 2017 9:26pm
Scottyav
Gives some the chance to save up as it seems others have got up to 30k more or they sell it and also with the paper in the filters and tc it protects from tearing more with the teflon coating 😉 _____________________________________________________
Post #446593 4th Aug 2017 3:20am
horse86
bump.....
2008 FFRR (sold)
2008 BMW M5
Post #447087 8th Aug 2017 6:46pm
Weegie
I believe he means use the filler plug hole not the drain plug hole. Wink As said, keep the engine running when removing the filler plug. Otherwise the fluid drains back out of the torque converter and runs out of the filler plug hole. John
GAP iiD BT-Sold
Post #447094 8th Aug 2017 7:13pm
horse86
ah ok....I'm not as up to speed on the "English" terms....crazy Brits....or Americans...I don't know which ones Laughing 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #447105 8th Aug 2017 7:38pm
