Home > Camping, Caravanning and Holidays > What paint to use
Wogger
England 2010 Range Rover Vogue TDV8 Orkney Grey
What paint to use
One of my offspring has aquired a 32 year old Castleton caravan, which needs some renovation, which we intend to do ourselves.
The body of the van is made up of grp and aluminium, what paint can we use for both surfaces, bearing in mind we want to brush and roller it on.
We're not after a showroom finish, just something presentable
Cheers
Post #446406 2nd Aug 2017 11:05am
Baltic Blue
Tekaloid coach paint is brilliant, but only if you use the proper Tekaloid undercoat.
It is good for brush application and gives an excellent finish, but not sure about using a roller? G reg 2.5VM Vogue Portofino red 1991- 1999
Post #446409 2nd Aug 2017 11:49am
buffalo4
2009 Range Rover Vogue SE TDV8 Bournville
whatever product you use, the finish will only be reflected in the preparation you make.. Thumbs Up
Post #446422 2nd Aug 2017 3:01pm
mzplcg
OK, being brutally frank your options with a brush or a roller are limited to slow drying paint which means much more time for dust and dirt particles to settle in it, especially the roof but also the sides on a windy day. Plus any bits of fur from the dog passing by etc, you know the score.
Any synthetic paint (including coachwork paint) is slower drying than the cellulose based or Acrylic paints. Unless you have proper breathing gear you should avoid 2K Acrylic anyway. The hardener is isocyanate based and it's no idle coincidence that sounds like the word cyanide.
Personally, if it were me, I would spray it with cellulose after using a blocking (bar coat) primer. Rent a spray gun and compressor for the day. Not only will it be much quicker it will look loads better. The other alternative would be to try and find a place under cover to paint it with a roller and coachwork paint.
Post #446488 3rd Aug 2017 8:48am
i think a clue is in the OP's post Wink ,
''We're not after a showroom finish, just something presentable '' ... - .- -.
Post #446490 3rd Aug 2017 8:53am
mzplcg
Paint full of dirt is hardly presentable Stan, of course it depends on personal views but if it ends up being as bad as it started then why bother at all?
Post #446492 3rd Aug 2017 9:11am
Wogger
Just to let you know chaps, we've painted the van and it looks ok, not showroom, but ok.
You can see a few roller marks, but it covered ok.
We've put the trim back on the van, new tyres and sky lights and if I'm.honest it's good.
Just the interior to sort next.
Got a lot more character than our new Lunar Delta, but how caravan building has come on in 30 years.
And there's money to be made from this caravan restoration lark, we've doubled our outlay already Thumbs Up
Post #447649 12th Aug 2017 8:23pm
