Home > Technical (L405) > Number Plate
danp03
Number Plate
Hi, does anyone know the standard size of the rear plate on the L405? Many Thanks. Dan
Post #446389 2nd Aug 2017 7:50am
Fat Wolfie
Got my private plate waiting to be put on so have measured it...
535mm long, 127 high.
Bigger than the front (standard) 520 by 110.
To fit MY 2017 405
Hope this helps!
Post #446390 2nd Aug 2017 8:00am
standard is 520x110 [as said above] but you can have whatever size you want as long as the letters and numbers are a specific legal size.. ... - .- -.
Post #446394 2nd Aug 2017 8:22am
Fat Wolfie
Absolutely right Stan.
Plates were made by main dealer and are the same size as they appply to all new and approved FFRR that they sell. So it looks like the 405 rear plate space is better filled by a slightly larger plate but probably no reason why the standard size won't fit.
Post #446396 2nd Aug 2017 8:32am
we had the standard v larger rear plate discussion many years ago on the forum Laughing ... - .- -.
Post #446397 2nd Aug 2017 8:38am
danp03
Many Thanks, collecting the new (to me) car back end of the week and wanting to get the plates made up
Post #446401 2nd Aug 2017 9:40am
the dealer will supply the plates?
unless they are differently spaced letters/numbers on your reg.. ... - .- -.
Post #446402 2nd Aug 2017 9:46am
danp03
To fit MY 2017 405
Hope this helps!
Many Thanks, the only size I am seem to get is 21 inches by 6 inches. Making the height an inch larger than what you have specified, I'm assuming this size is L322? Will this size fit the L405 and secondly will it look out of place? Thanks.
Post #446404 2nd Aug 2017 9:54am
danp03
Hi Stan
They are supplying but I'm a little naughty with the spacing on one of the letters. With this in mind will a 21 x 6 fit? Or is this the L322 size? Many Thanks. Dan
Post #446408 2nd Aug 2017 10:38am
these bigger plates are fitted to some L322 and so are the normal size plates...
this pic shows a L405 with a normal plate,
this pic shows a larger plate, could be the same size as you want but its difficult to tell,
Post #446411 2nd Aug 2017 11:37am
I'm sure mine are 20.5x6 (520x152) but not with the car at the moment.
I got mine from FancyPlates
Post #446413 2nd Aug 2017 12:28pm
danp03
Thanks Guys, I have ordered 21 x 6 for rear and standard for the front. Looking forward to collection day. Very Happy
Post #446418 2nd Aug 2017 1:09pm
jumpin mouse
United Kingdom 2015 Range Rover Autobiography SDV8 Aruba
My dealer called it a "one and a half" plate but I don't know if that's a standard term.
Post #446435 2nd Aug 2017 3:56pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Had my private plate added to my car and the Main Dealer charged me £70 for the privilege. The only thing I can say about them are they are on Aluminium rather than plastic backing.Yes the rear is larger than the front.
Autobiography 3.0 14M5
Post #446691 5th Aug 2017 6:27am
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
I'm going the other way, so I'm currently on the look out for short (but legal) plates for a 3 digit number.
The dealer has agreed not to fit the black plastic number plate holder to the front, so I'll be interested to see how it looks.
Post #446693 5th Aug 2017 8:52am
