Home > Technical (L322) > Fuel flap door wont open |
pia1361 Member Since: 24 Apr 2012 Location: guildford Posts: 19 |
Hi
4th Feb 2018 12:08pm |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Hi John i havent yet sorted it no im afraid. There is a green manual release cable in the boot area if you remove the cover pull it and it pulls back the plastic bolt. I can open mine if i unlock the car and quickly pull the flap as the plastic bolt goes back and the comes forward a bit. I then need to lock then unlock the car with the flap practically closed resting on the bolt to lock it again. A pain but its workable! You can buy a new or used actuator off ebay but i havent looked at how to remove the old one but think thats what i am ultimately going to have to do. Current 2007 TDV8 Vogue Buckingham Blue |
4th Feb 2018 3:15pm |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
I had a similar problem - although mine wouldn’t lock rather than unlock.
4th Feb 2018 3:41pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
Mine did this and the plunger housing wasn't seated properly |
4th Feb 2018 5:43pm |
How did you diagnose that sandyt? Will need to have a look and see if mine is Current 2007 TDV8 Vogue Buckingham Blue |
4th Feb 2018 6:25pm |
What I did was open the fuel flap then with it open lock the car and watch the plunger mine was coming out but bringing the sheath with it so when it was opened it didn't retract fully - one identified just put a dab of silicon on to hold it it
4th Feb 2018 6:53pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Inner plastic wheel arch needs to come off in order to get at everything .
4th Feb 2018 8:38pm |
AM Member Since: 27 Jun 2021 Location: Abu Dhabi Posts: 2 |
Hello kbald,
27th Jun 2021 7:42am |
Hi I never did get round to fixing it yet. Sometimes it's fine,sometimes not, so learned to live with it but will need doing at some point. Current 2007 TDV8 Vogue Buckingham Blue |
27th Jun 2021 12:05pm |
My problem is sorted out, not sure for how long though. I manually pulled the emergency handle to open the flap door. It’s in the right side side of the trunk, you’ll see the handle once you remove the panel. And after that plunger started moving properly |
31st Jul 2021 8:29am |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 350 |
I found that if you press the unlock button on the key just before trying to open the flap it retracts the pin enough to let you open it, I’ve got to get it adjusted but it works most of the time 2012 Range Rover Westminster 4.4 TDV8
31st Jul 2021 2:35pm |
