Home > Technical (L322) > Heavy steering
Johnsd1v8
United Kingdom 2004 Range Rover Autobiography Td6 Zambezi Silver
Heavy steering
So people i know this has been coverd on here i have a ffrr l322 my05 anyway had this bit of anoying issue the steering goes very heavy the 1st time this happend i sprayed the shaft knuckles with wd40 from underneath and steering was light i thought right i need new shaft anyway its done it again so i wobbled the wire feeding the servotronic valve and again steering works so is it the plug that is dodgy or the wiring where on the wire would be the best place on the wiring to look thanks guys
Post #446228 31st Jul 2017 6:32am
i'd concentrate on the wiring ..unplug it and check it thoroughly ... ... - .- -.
Post #446231 31st Jul 2017 8:17am
Johnsd1v8
Thanks stan ill have a good look at that i hope its not the servotronic as i belive the bolts tend to snap
Post #446233 31st Jul 2017 8:25am
Cooper1275
Ireland 2006 Range Rover Vogue SE Td6 Buckingham Blue
Does your central locking act up when this happens?
There is also a "bug" where the steering goes heavy and the central locking acts up. For mine the two rear doors wont unlock. I press the central locking button a few times and when it begins to work as normal turn the car off and on again.
Voila! light steering.
It happens very rarely but the above fixes it. Rolling Eyes
Post #446241 31st Jul 2017 12:25pm
Johnsd1v8
Some times ive noticed the rear door locks pop before the fronts only like a split second but you can hear the rears unlock 1st doesnt do it that often and to be honest ove never noticed if this messes with the steering
Post #446243 31st Jul 2017 12:41pm
Cooper1275
Ah yes they are connected....
http://www.fullfatrr.com/forum/topic30730....ng+central
http://www.fullfatrr.com/forum/topic37139....ng+central
I just live with it as its a pretty rare occurrence.
Post #446244 31st Jul 2017 12:46pm
Johnsd1v8
Nice cars these but they are weird at the same time
Post #446251 31st Jul 2017 1:43pm
bebechoon
France
Picking up on Cooper1275's comments Thumbs Up , I had the heavy steering and rear door and filler cap locking gremlins which were all connected and all fixed by replacing the BCU. That also, unexpectedly, cured an intermittent rear parking sensor problem too.
See my write-up in the Wiki:
http://www.fullfatrr.com/forum/topic40009.html
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #446279 31st Jul 2017 7:06pm
