Home > Wheels & Tyres > 18" steel wheels for L322
CDN38
Canada
I'm crossing over from the Defender world and am starting on the learning curve over here. I have an 05 RR with a stock set up 19" wheels and want to have a more aggressive tire.(thinking along the lines of a BFG All Terrain. It's pretty much the best solution tire wise for our terrain here).
Thinking 18" has a better selection, also looking at the opportunity to go to a stronger wheel of steel rather than alloy. (I have Matt Lee's on my Defender).
What are the recommendations, as well as issues to look for, things to avoid? From what I have been reading, brake caliber clearance could be one issue, and clearance for the tires the other.
Post #445878 26th Jul 2017 7:23pm
fisha
Yes, the 18" wheel size has more options ... but it depends on the model of RR you want to buy and the age of it.
There are loads of threads on here and other forums which discuss it. In general, the later the model, the bigger the calipers, the less possible 18" are. By age, generally:
Upto 2006 - generally can fit 18"
2006 - 2010 - less likely / not possible without specialist wheels. The only ones I know of are Compomotive PD1881.
Post 2010 - I think the calipers prevent 18" full stop.
LR original 18" wheels generally sit quite in from the side of the body, so have limited space on the inner arch areas for for wide tyres. spacers may be needed.
As for steel wheels, I never found any obvious ones in the UK. Don't know about Canada. I have PD1881's on My supercharged. V8 or else ...
Post #445883 26th Jul 2017 8:20pm
rar110
Your year FFRR will be able to take the Range Rover 18" alloys. That will be the cheapest option. These are quite robustly build. Below is a pick of one style I have. I have 265/60/18s fitted with no rubbing issues. This size tyre also fit in the spare wheel wheel.
 ______________________________
Post #445886 26th Jul 2017 8:41pm
CDN38
Canada
1t's a 2005, so I am thinking 18's will work.
This truck has a lift, which at this point I want to look into just so I know where I can eventually go, but probably not in the cards quite yet.
Anyone recognize the wheel tire combo?
Post #445889 26th Jul 2017 9:12pm
rar110
Has this had a coil replacement or is EAS at full height? ______________________________
Post #445905 27th Jul 2017 6:09am
CDN38
Canada
Based on the tire size (I'm guessing 33" or so) I'm pretty sure it's had a spring conversion.
Post #446070 28th Jul 2017 8:54pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Pretty sure the one with 33" above just has a 2" lift via height sensor rods.
Post #446109 29th Jul 2017 12:05pm
Rorowe
United Kingdom 2006 Range Rover Vogue 4.4 V8 Lucerne Green
(New member) Not sure if this is the right place to post, but I have a set of 18" alloys with A/T tyres which I am thinking of selling (haven't' got around to listing anywhere yet). Please let me know if of any interest. Thanks.
Post #447377 10th Aug 2017 2:01pm
Weegie
Welcome aboard the forum.
I think cost of shipping might be a problem. John
GAP iiD BT
Post #447379 10th Aug 2017 2:07pm
Rorowe
Ah, yes. Hadn't registered location....
Post #447394 10th Aug 2017 4:43pm
