![]() | Home > Technical (L322) > Engine System Fault |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 ![]() ![]() ![]() |
Hi Andy its quite probably a split top hose which is a very common problem and easy to fix. Have a search on the forum for it but its easy to check the main two. They go from the front top of the engine and have a jubilee clip either side to remove. Also check under the webbing on the right hand one aswell. Hope this helps. Current 2007 TDV8 Vogue Buckingham Blue |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 750 ![]() ![]() ![]() |
Had the same symptoms! Caravan on the back too!! Turbo hose split!
Andy Cox Member Since: 24 Dec 2016 Location: Cornwall Posts: 45 ![]() ![]() ![]() |
Thanks guys, I'll check it out.
RHV8 Member Since: 03 Aug 2017 Location: Sutton in ashfield Posts: 2 ![]() ![]() ![]() |
Had the same with my 09 and just bought a lynx evo tells me it's map sensor on bank A currently waiting for new sensor |
Sorry for disappearing for a while, I had to rush off to my elderly mothers aid in Hampshire for the last week or so. She has no need for the interweb and there's no mobile signal either so I was a bit cut off!
OK, so it turns out the problem is a split in the right hand inlet manifold which is plastic and part of the rocker cover assembly apparently and is quite common so I've been told.
