![]() | Home > Technical (L322) > Eaton M112....The old & the new!??! |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
So what happened to the old supercharger? ______________________________
Dreckly Member Since: 16 Apr 2015 Location: Truro, Cornwall Posts: 47 ![]() ![]() ![]() |
I have a really harsh bearing noise coming from high up in the area around the rear of the charger. The usual thing....the noise was only under load and roughly between 1800 & 2300 rpm (the rev range where most driving is done), so I am thinking that it is the rear bearings in the charger. My car has done 186K miles so my thinking is that the charger bearings would probably need replacing. I also really fancied a 10% pulley upgrade so when I found a NOS unit with unmarked teflon coated rotors on the bay of thieves for silly money, it was a no brain decision. I had the new charger sent to Powerhouse who checked it over (yes definitely new), re-greased the bearings (as a sensible precaution) & installed the new pulley. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
sweet thanks for sharing this indeed. Looking forward to the install pics too if you don't mind, then video with sound!!! |
I took pictures all the way through the strip down so can do a blow by blow pictorial account of removal then rebuild if people want!??! 55 S/C L322 Zambesi Silver.....GONE!!
thanks, that would be very useful for the wiki here. |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 605 ![]() ![]() ![]() |
we want |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 ![]() ![]() ![]() |
Want one, want one, as you have a stopwatch in the screen menu 0-60mph might be interesting.
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Yes that would be good to see thanks.
Did it cure the noise is the main question |
Hi All,
Very Disco..... I'll write a "How to" when I've finished it all, and managed to compress the pictures etc. |
Sounds good and looking forward to the pictures
I've got the IID BT version and it gives me the option of lower again than access height, which from memory is the transportation setting & probably used for going on and off car transporters.
Well I drove her yesterday for a 40 odd mile round trip. All "A" roads (there are no motorways in Cornwall) and a what a pleasing difference. |
