Home > Maintenance & Mods (L322) > Tailgate rust prevention
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Hi folks,
With the weather being good I decided to treat the tailgate for the usual rust at the edges.
I noticed a few bubbles at the inside edge at the bottom, the rust had not made through the paint so I wanted to take preventative action to avoid it happening. When I took the trim off I could see the rust in the seems.. clearly the water sits there causing rust.
Step 1: Take the trim off which is held by 2 screws and retaining clips which come off easily. Beware as the edge of the plastic trim is really sharp. I used Dynax S-50 spray which comes with a tube very handy to treat behind the bit where the Range Rover badge is.
Step 2: Reach out to the cavities from the voids, spray the treatment and pull the tube for full coverage.
Step 3: Once you are happy with the full coverage from left to right, put a sheet on the floor (excess liquid drips until it cures from the two drain holes on either side) and leave it tilted for few hours. I left it alone while I cut the hedge Smile
Mine is out of warranty so the idea of having to replace the tailgate is not good. Hopefully this will look after it. The Dynax stuff has got good reviews so fingers crossed.. Hope this helps folks any questions give me a shout. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #445608 24th Jul 2017 8:48pm
rar110
Great job. Thanks. ______________________________
Post #445620 24th Jul 2017 9:57pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I did this with Dynax S50 on my 2003 a few years back. No rust yet. Or at least, no rust on the tailgate, now the rear of the sills is a different matter, didn't do them in time!! Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #445653 25th Jul 2017 8:54am
scotcruz
rvbush can you post the location of the rust on the sills? Im thinking I shoukd treat them while im at it. Current:
Past:
Post #445663 25th Jul 2017 9:34am
rvbush
Yes of course, it's behind the plastic sill finisher inside the rear door shuts where the arch meets the sill. I only spotted it when it surfaced above the plastic sill trim (as bubbled paint). I haven't removed anything to look at it as I think it's likely to be quite bad on mine (I don't really want to know!). I drilled a hole in the arch liner and pumped it full of Dynax as well as tucking it behind the plastic finisher. I just hope is slows progress a bit. Drives:
Post #445784 26th Jul 2017 8:52am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi
Does the Dynax also kill any rust which may be present? I too have some slight bubbling and wonder if this product is only a preventative and not a cure??
Cheers Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #445829 26th Jul 2017 1:50pm
rvbush
According to the bumf on the can it protects both new and corroded metal. Drives:
Post #445831 26th Jul 2017 1:54pm
dan_uk_1984
Brilliant post - will deffo be giving this a go! Thumbs Up
Post #445832 26th Jul 2017 2:03pm
Les_Paul
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
Do these rust because of ice and snow in the winters? I'm in southern Texas and only have to deal with rain. We've had snow 4 or 5 times in my 20 years living here!
Post #445903 27th Jul 2017 2:12am
scotcruz
Its a design fault Les Paul but think you might be ok in Texas as its a totally different climate.. No harm in applying it for peace of mind though.
I could see mind was started to rust in between the seem.. before putting it back I could see the rust was nicely covered with Dynax stuff so am really pleased. Current:
Past:
Post #445907 27th Jul 2017 7:16am
Weegie
Instead of removing the cappings could you not use the drain holes to insert the product? The tubes supplied are quite long and slim enough to pass inside via the drain holes. John
GAP iiD BT-Sold
Post #446245 31st Jul 2017 1:50pm
rvbush
That's what I did. Drives:
Post #446246 31st Jul 2017 1:56pm
scotcruz
yes but it wont get all the way through behind the RR badge. This way i had full coverage i.e. 2 inches up the rear panel and about the same at the bottom panel.
There are only 2 screws anyway and if you are going through the effort may as well do it properly. Current:
Past:
Post #446247 31st Jul 2017 1:57pm
Weegie
Thanks for the replies. Thumbs Up John
GAP iiD BT-Sold
Post #446248 31st Jul 2017 2:08pm
jjfang
Any update on how well the Dynax S50 is performing ? I’ve seen many products that say you can go over rust that don’t really work, how well is it working for you? I’ve been using Fluid Fulm/Wool Wax in the states and that does work well and it’s stopped the rust for me but since it’s always liquid in the summer it drips non-stop
Post #586437 6th Mar 2021 5:37am
