Home > Maintenance & Mods (L322) > Intercooler hoses
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Intercooler hoses
Hi gang
Just to compound all the issues I've been having lately, I had my dash light up like Blackpool in December mid last week and reduced power etc... Managed to limp back to a garage local to me and sat outside from 7am (I was on my way to work when it happened) A quick look when they opened and told me nothing serious - Just intercooler hose. They duly replaced it for £65 including fitting and I was on my way..
Happy with that...... Until today...... On my way home from work round the lovely M25, my dash lit up again and saw plumes of nice black smoke when I tried to accelerate. Pulled over to the hard shoulder and turned the car off and on again and it seemed to reset it. I took it slowly and got home ok with no further issues.
On inspection in my drive it appears I now have a tear in the other intercooler hose (this time the left one as you look from the front)
Not actually a big problem as i suspect it will be fairly cheap and easy to fit but is it usual for both to go (or one to follow the other soon afterwards). Are they something that should be done in pairs..?
I guess my bigger question would be could there be anything more sinister causing them to go that I should be aware of.?
Thanks again folks as always... Ash
2016 SDV8 AB
Post #445605 24th Jul 2017 7:27pm
It is generally the right one which goes, that said when I did mine on the 3,6 I did them both. There are a couple at the bottom of the inter cooler too and some short ones near the turbo. The hoses at the bottom of the inter cooler are pretty easy the ones by the turbos tend to not ever get done as they are a lot more work and I can only remember 1 story of these going pop on here.
Do the other one, leave the bottom ones and do them when they go. Carry a roll of the Harris hose tape in the boot.👍🏻 I would hazzard a guess it's just about the right time for them to go..... wouldn't worry too unduly. There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 24th Jul 2017 7:37pm. Edited 1 time in total
Post #445606 24th Jul 2017 7:36pm
Mikey
Same issue when replacing a single turbo. If one has gone, the other is likely not far behind... Big Cry
Post #445607 24th Jul 2017 7:36pm
comports
that sounds a tad more expensive than my hose issues
Thanks both - As long as its not likely to be something more causing them to go - I'll put it down to age so it makes sense for the other to go if the first one has.
Finger crossed it will all be fine when I get it replaced.
Cheers Ash
2016 SDV8 AB
Post #445610 24th Jul 2017 7:58pm
comports
Thanks all for the info.
One more question if I may - I had a quick look and it seems its only a hose held on with jubilee clips..??
If this is correct and I don't need to do anything else, I think I should order it up and fit it myself. Just not sure if I would need anything else (oil top up, dismantle half an engine to get to it etc etc..)
could you let me know if it is as simple as undo old, remove, push on new and tighten clips.?
Thanks Ash
2016 SDV8 AB
Post #445643 25th Jul 2017 6:45am
Yep, 2 x jubilee clip.
Undo, remove, fit new one, do up clips Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #445645 25th Jul 2017 7:28am
It's as easy a DIY job as they come Thumbs Up
Post #445650 25th Jul 2017 7:49am
comports
read a bit about the silicon hoses so ordered some as an "upgrade" - on a 10am delivery tomorrow so hopefully back up and running tomorrow (will fit when I get home after work
Thanks again..! Ash
2016 SDV8 AB
Post #445652 25th Jul 2017 7:54am
I had a silicone hose pack - it arrived with 6 hoses, but I only ever fitted the top 2 as they were easy - never got around to the rest ......
Post #445667 25th Jul 2017 8:45am
2 big for top
2 big for bottom
2 small for turbo. 4 easy to fit, 2 small ones are for by the turbo and are more harder...... There is nothing that can't be fixed with a hammer😜😜
Post #445763 25th Jul 2017 8:26pm
