Home > In Car Electronics (L322) > bmw hybrid digital tv tuner help needed
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Hi Guys looking for someone who has done this and can answer some questions please.
I have seen several posts that say this is plug and play I have a 2002 l322 can bus will it plug and play in this?
Secondly all the upgrades I have seen require a remote for the channel search how does the hybrid box tune to the channels?
finally what tuner should I be looking to buy and has anyone got any part numbers that are compatible?
Any information would be greatly appreciated
Post #445567 24th Jul 2017 11:57am
Clivefog
I got one from a dismantlers yard BMW, £20 as they did not know what it was, and a fancy cable which was not in my 2003 and as it turns out works an add on rear view camera - double result!
Yes plug and play and only one retaining screw. do a search on Ebay for BMW digital TV tuner 2002-2006 and you should find some with part numbers.
Post #445569 24th Jul 2017 12:05pm
As above, the hybrid unit is a straight swap, all tuning etc. done on main screen buttons up front, no remote required.
There are third party options for adding dvb tuner to the party, this will require a remote. You can also get your existing unit upgraded to DVB. .
Post #445578 24th Jul 2017 1:42pm
horsedentist
Thanks guys do you need to change the antenna or is the analogue one ok?
Thanks for all other answers.
Post #445591 24th Jul 2017 4:05pm
Weegie
No need to change the antenna. John
GAP iiD BT
Post #445592 24th Jul 2017 4:16pm
horsedentist
Thank you for your help just need to find a good priced one now.
Post #445628 24th Jul 2017 9:28pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I have one for sale, it's not a new hybrid it's a genuine land rover tv box with digital upgrades inside, everything works from the head unit buttons, it come with the fancy cable mentioned above A/V in and out camera input and even camera relay which is needed
Whole unit aerial converters and A/V cable is £300 plus delivery
Post #445725 25th Jul 2017 3:25pm
