Home > In Car Electronics (L322) > 2003 l322 digital TV upgrade
Ringochi
England 2003 Range Rover Vogue SE Td6 Epsom Green
Hi guys I have a 2003 l322 with the BMW tv tuner and am looking to upgrade it to digital. Any ideas how I can do this please? Many thanks
Post #445365 22nd Jul 2017 3:22pm
Buy and hybrid Analog/Digital TV unit and simply swap over - plug and play.
This is the easiest way - there are others.... .
Post #445366 22nd Jul 2017 3:31pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Re: 2003 l322 digital TV upgrade
Unnecessary quote removed
I have a full digital tv setup works via headunit, about inputs and outputs with reverse input and wiring relay all for £300 delivered
Post #445413 22nd Jul 2017 8:27pm
Gold Ranger
United Kingdom 2010 Range Rover Vogue TDV8 Santorini Black
http://www.carphonics.co.uk/digitaltv.htm
Land Rover L322 DVB-T Digital Freeview TV Upgrade
info from their site
This is for upgrading your original analogue tuner to digital TV and DAB Radio, as well as Multimedia USB connection. Your analogue TV Tuner will have to be sent to for the upgrade, or alternatively, buy a ready made unit from and receive a partial refund for the difference.
Post #445471 23rd Jul 2017 11:25am
Lukie
Based on the above website my DVB tuner would be stage 2 with more functions
Post #445546 23rd Jul 2017 9:23pm
SamUK
England 2005 Range Rover Vogue Td6 Zambezi Silver
Are there any companies do this for the touch screen variant? I got excited when I read this for a moment, clicked the link and ..... Not for touch screen models!
Post #448742 22nd Aug 2017 7:02pm
p38arover
Australia
This is a very easy one to fix.
Have a look at http://PiBus.info/tv
I did this mod two weeks ago. The hardest part is drilling two holes for the aerial connectors Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #448778 22nd Aug 2017 10:56pm
SamUK
Perfect.. That doesn't seem to much of a job to do either. My next question is, how do I remove the head unit/touch screen? I'm new to the l322' and if I'm honest taking it apart does concern me a little as everything on them seems to be so expensive to repair/replace.
Post #448788 23rd Aug 2017 7:34am
^ sam, that link is for the original posters question and he has a different system to yours..
yours is a MOST system which cant be upgraded except for the tuner which is replaceable with a hybrid tuner...do a search theres info on this...... ... - .- -.
Post #448789 23rd Aug 2017 7:40am
SamUK
Ahh, ok. Thanks for clearing that up Stan. I'll start searching.
Post #448796 23rd Aug 2017 9:16am
Fly-Boy
France
Hello Stan,
Apologies for digging out this old thread... Hopefully you can help : My 2006 Vogue had the analogue tuner so that I lost all channels when France switched over to digital TV a few years ago.
I bought a used L322 HYBRID TV module (P/N : UH42-19C063-BC) which I just swapped with the original module, as recommended here and there, presumably it should be a "plug & play" operation...
Sad Bummer, still cannot receive any program... When I select "Auto" tuning, nothing happens. In "Manual" mode the system just jumps channels 1, 2, ... 69 with no more than buzzing sounds and "snow" on the screen.
It seems the tuner seeks only for analogue signals : indeed when going to TV / Settings / System, the drop list only offers the old analogue decoders (PAL, SECAM, NTSC), no choice for DVB, MPEG or the like... Hence my question : is it necessary to "tell" the head unit that a different TV tuner is installed ?
I have accessed the "hidden" MOST diagnostic mode and in the car configuration screen, I can see one line : "TVVariant" with parameter "TV 1 fitted". Is this related to the tuner type ? If yes, how to update it to "TV 2" or so ?
Another guess (less probable IMO but never knows...) : could it be that the Hybrid tuner I purchased is not compatible ? I should have mentionned that despite the tuner bears "L322 HYBRID" its donor car was a 2009 Discovery 3...
Any comment welcome !
Cheers,
Marc
Post #544982 24th Feb 2020 9:42am
Weegie
You won't get TV in France with any of the LR tuners. France switched to MPEG4 for terrestrial TV and the LR tuners are MPEG2.
I have tried. Sad John
GAP iiD BT
Post #544993 24th Feb 2020 10:25am
p38arover
Australia
That's France for you.
Reminds me of the analogue TV days when some parts of the world, e.g., USA, Japan, etc., were NTSC - Never Twice the Same Colour
The enlightened world went PAL - Perfect At Last (or Peace at Last)
and France went SECAM - Something Essentially Contrary to the American Method Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #544997 24th Feb 2020 10:58am
Fly-Boy
France
Very interesting ! This makes sense. Thanks John !
Are you saying that the TV on subsequent YM cars (2007 onwards...) factory fitted with LR hybrid TV tuner doesn't operate in France ?
If the case, I guess the MPEG4 compatibility should have been introduced by LR at some point... Hopefully in the latest L322s YM (2012 ?) so that a swap with the correct tuner may be possible. Any idea ?
Post #545001 24th Feb 2020 11:26am
the irish and scandinavian countrys have the same problem ..
do a forum search on 'mpeg4'.. ... - .- -.
Post #545002 24th Feb 2020 11:33am
