![]() | Home > In Car Electronics (L322) > TV sound drops out |
Shaun_ Member Since: 02 Feb 2017 Location: New Forest Posts: 74 ![]() ![]() ![]() |
Hi All
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
I have exactly the same issue & assumed that it was purely down to the reception that I was receiving. Interesting to see if anyone has other thoughts. |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 ![]() ![]() ![]() |
I find the sound is the first thing that starts dropping intermittently when the signal is getting weaker. Once the audio starts dropping out and coming back, we normally then lose the picture in a bit, or we turn it off because we get fed up with it!
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I've had the same problem with my last two RRs. My research indicated some sort of conflict with Bluetooth phone usage. The phone is communicating regularly and interfering with TV audio. I need the phone connection and don't use the tv so never bothered to unpair and check. 2012 5.0L S/C
I do have the phone paired most of the time as well, so could tie in.
Used the TV yesterday & having the sound cut out every so often along with some pixelation.
