Home > Technical (L322) > MPG calculator accuracy
Baltic Blue
I have just returned from a weekend away and thought I would take the opportunity to check the trip computer accuracy.
I brimmed the tank on Friday. 478 miles back to same garage, trip computer said 34.1mpg.
My calculations using free iPhone app came to 33.8mpg.
Near enough for me and very happy with mpg given it included several motorway jams in roadworks on M5 and M6 plus some nightmare driving in heavy London traffic. Incidentally, when I brimmed it on my return it showed a range of 578miles, which is the highest I have ever seen it read.
It will now take me the rest of the week to clean all the dead flies off.
Cheers
Just found receipt for fuel. It used 63.6 litres . G reg 2.5VM Vogue Portofino red 1991- 1999
Post #444802 17th Jul 2017 2:44pm
Andyyav
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Got to be pleased with that!
According to the OBC i get 24 ish from my 07 TDV8 on my daily commute, I'm running general grabber AT's at 36 PSI might have a play with pressures to see if makes any difference 🤔
Post #445096 19th Jul 2017 8:47pm
stu
Blimey, never seen as much as 30 mpg since I got it earlier this year!
My.wife has just driven 380 miles and the computer said 28.7, so happy with that! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #445196 20th Jul 2017 6:50pm
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I have just done two full to empty fills and reset the mpg and miles at fill time. Both times the fuel computer gave a slightly different mpg than I was actually getting. Then i included the roughly 5% inaccuracy in my speedo, it over reads approx 5% at all speeds, and the computer was pretty much spot on.
I tend to get between 25 and 27mog on my TD6, which seems very low compared to others here. RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #445247 21st Jul 2017 10:15am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
Low? I get 19 on my TD6 :/ must be knackered!
Post #445261 21st Jul 2017 11:43am
DarkWheel
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Zambezi Silver
My 2004 4.4 V8 returns a crippling 14.7 - I'm running it on LPG though which takes a lot of the pain (But not all!)
Post #445275 21st Jul 2017 1:25pm
Shaun_
Overall, according to the 'Fuelio' app I have on my smartphone and based on several months driving now, my 07 3.6 TDV8 has returned 30.5 mpg. That's based on a range of driving styles, from short shopping trips to road trips abroad, and my daily 90 mile commute on a congested M27.
I'm very happy with that given the weight and performance of the car, and most people find it hard to believe.
The computer generally indicates a figure about 7% optimistic. 2012 TDV8 Westminster in the New Forest
Also: Land Rover Series 3 SWB, Mercedes 280SL, Classic Mini race replica, VW Golf SV
Previously: Audi A8, RR TDV8 Vogue, Audi Allroad, VW Golf GTI Edition 30, Audi A4 Avant, A8, A4 Sport, A6, VW Golf Mk5, Bora, Golf GTI Mk3, Jetta Mk3, Passat, Jetta Mk1, Golf Mk1
Post #445278 21st Jul 2017 2:40pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Same Boat here, Mixed i get around 15/16mpg
Motorway only its 22mpg. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #445345 22nd Jul 2017 1:11pm
jz
INACCURATE FUEL GUAGE READING - LR SENDER WIRING MOD?
Hi...
2011 5L SC currently in with dealer having the wiring modification done to fix inaccurate reading, so a question please to those who own the same.
When filled to the brim, what does the trip computer tell you the mileage range is - mine before going in for work to be done showed ~338miles is that in-line with others?
Many thanks!
Post #463986 10th Jan 2018 11:54am
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
My 05 SC averages around 17mpg
On a 2,000 mile trip in Europe I averaged 20.1mpg with four of us in the car, bike rack on tow bar and the boot full to the roof, so not too bad overall!
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #463988 10th Jan 2018 11:59am
sounds about right..i got similar mpg with my sc... ... - .- -.
Post #463995 10th Jan 2018 12:53pm
Paulus1978
England 2008 Range Rover Vogue SE TDV8 Santorini Black
Sounds good. I recorded 33.8 on a run down to Tilbury and back the other week.
Seems the trick to good MPG is gentle gearshifts when pulling away at the lights, not minding sticking her at 60MPH on Cruise Control, and making sure she has good quality fuel in the tank.
Post #464048 10th Jan 2018 7:00pm
