![]() | Home > General (L405) > I might be joining the big boys club, whats your views on... |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Stick.
bear100 Member Since: 22 May 2011 Location: south wales Posts: 204 ![]() ![]() ![]() |
Go for it, you wont regret it they are chalk and cheese |
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
It's a no brainier to try both engines first before you part with so much money. The 3.0 is as quick as yours, more refined than both yours and the l405 V8 and pretty good on fuel. The V8 is noticeably quicker than yours and again surprisingly good on fuel and again a good engine. For my two penneth worth I'd also look at something with less miles if you can afford it, even if it means picking a well specked SE. The engine would come second place to picking a well cared for car with enough kit in it to make driving special |
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
Thankyou for that.
362bkr Member Since: 15 Oct 2014 Location: Devon Posts: 679 ![]() ![]() ![]() |
The one in the link is a vogue so won't have adaptive cruise control . I agree the SE offers a great compromise and I rate the 3 litre v6 . Try and get one with front fog lights as they are only standard on the autobiography , which is a bit daft. |
Pixelpower Member Since: 16 Jul 2014 Location: Droitwich Posts: 204 ![]() ![]() ![]() |
That one looks a bit poverty spec. Who doesn't spec the fog lights! |
These 405's around the £50k mark are a nightmare |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7969 ![]() ![]() ![]() |
Front fogs are really a waste of time IMHO as actual lights, but I do think they look better with them.
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
I agree with the SE comment, and anything around needs the 2 year warranty alaso I'd say.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1392 ![]() ![]() ![]() |
You will know when it's time to change, but for me to pay £25,000 extra for a car that is about the same age, with the same engine and about the same mileage would not make sense, even allowing for the greater performance and refinement of the 405 and the reduced corrosion risk, against reduced luggage space.
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1153 ![]() ![]() ![]() |
I completely agree with CS. |
Thanks,
I don't know whether LR dealers would be open enough to tell you, but a starting point might be jonttt's thread "My 405 is terminal" and you could use the search facility with "seized 3.0" or the like. His one seemed to be a 2015. Only Range Rovers since 1988 |
