Home > In Car Electronics (L322) > Amp wiring for a LC8
Cheebs
United States 2006 Range Rover HSE 4.4 V8 Lucerne Green
I am looking for the logic 7 amp wiring diagram for an 06 Range Rover hse. I have downloaded a few shop manuals but none seem to have the amp wiring. I just want to wire up an Audiocontrol lc8 for an after market amp.
Post #444420 13th Jul 2017 12:38am
Cheebs
Anyone? Big Cry
Post #444747 17th Jul 2017 5:29am
have you found anything on a forum search ? ... - .- -.
Post #444752 17th Jul 2017 7:01am
Cheebs
Yes and no. there are no clear this is the wiring diagram. There are a few for a 03 but my thinking is it is not the same. I could be wrong. some others are too small to make out what is what. some pictures don't work anymore.
Post #444866 18th Jul 2017 4:58am
SteMY06HSE
Qatar 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Hi Cheebs,
Check out the 2006 workshop manual version 2 link near the bottom of the wiki page.
there is an electrical folder there with the 2006 wiring diagrams pdf in it.
Page 135/136 shows the amp wiring.
I know its there as Stan wiki'd it for me. Screen grab below, you will need to go to the pdf for the full res that's printable.
Hope that helps.
Ste
Post #444882 18th Jul 2017 7:16am
Cheebs
ok i think i got it. I am assuming that the front driver per side share most of the same grounds? And is that a miss print on the f104 driver listed as a mid but it should be a low driver?
Post #444989 19th Jul 2017 3:03am
SteMY06HSE
Certainly looks like a misprint if you compare it to the corresponding RH side speaker layout.
Front mid and high ranges appear to share both +tive and -tive feeds from the amplifier.
If I remember from my youth messing with car stereos, the high range (tweeter) usually has a built in filter to cut out the low frequencies so shouldn't be a problem.
Post #444992 19th Jul 2017 5:08am
