Home > Technical (L322) > Airbag light on
Andy
Airbag light on
My airbag light has come on. Checked it with IID tool and it says Battery Disconnect. I reset it and cleared the fault but it's come back on again.
What is meant by battery disconnect in relation to the airbag and why is it still faulting?[/i]
Post #444929 18th Jul 2017 5:15pm
unsolicited
United Kingdom 2017 Range Rover 5.0 SC V8 Mariana Black
It's nothing to do with an airbag per-se. It is something to do with the SRS system though. Look at the positive battery connector and there is a wire with a yellow connector coming off it. That connects the SRS ECU to the explosive charge that disconnects the battery connection in a crash.
Mine has developed an intermittent bad connection at the yellow connector. Try wiggling the two halves of the connector. Fixes mine for a while, but I think I'll need to take it apart eventually.
Post #444934 18th Jul 2017 5:53pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I wouldn't take it apart being a charged circuit I would simply replace it
Post #444970 18th Jul 2017 8:59pm
Crispian22
I had this with mine the other week,tried to reset it with the iid tool but wouldn't clear it.
Turned out the battery voltage was on the low side,after a charge for a couple of hours and a run out it cleared itself.
Post #444974 18th Jul 2017 9:14pm
