Home > Technical (L322) > 4.2SC lumpy / rough running under load and low rpm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi All
My SC is running little lumpy recently, thought it was plugs changed them, then changed all the coil packs for new ones still lumpy, its at low rpm under load it happens, just not as smooth as it was / should be.
Also on tick over sounds like a knocking noise some of the time I will try and record it and post.
Any ideas?
Post #444377 12th Jul 2017 7:46pm
lighthouse
Update
All spark plugs changed, all coil packs changed, checked for leaks in the air intake.
Running rough like a dog, knocking noise you can hear in video and rough idea in other video. Also get following errors on IID tool shown in picture.
The MAF was replaced about 6 months ago and give a range of reading inline with what is expected.
Its driving me made.
https://vimeo.com/225816581
https://vimeo.com/225816361
Post #444766 17th Jul 2017 10:11am
lighthouse
Today I changed the MAP sensor still the same, hase now ordered new knock sensors and a compression testing kit.
Post #444800 17th Jul 2017 3:01pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Have you checked the oil filler cap is seated / sealing correctly, if its allowing air to pass it causes the symptons you're describing...
Post #444818 17th Jul 2017 6:23pm
lighthouse
not tried that there was little oil spray on the engine cover. I will order a cap.
Post #444831 17th Jul 2017 8:05pm
ebajema
I had similar issues with my SC in Nigeria and once I updated the Engine Management ECU with the latest software, all the issues went away.
This was after replacement of the fuel pump, complete clean of the fuel system and inlet tract, MAF replacement etc. hadn't done anything to improve it. So once I got hold of my Faultmate and found out how to reflash the ECUs, I did all relevant ECUs, only took about half an hour all in all !!! And afterwards she was purring like a kitten again !!!! MY 2010 5.0 SC Galway green and sand interior!!
Post #444891 18th Jul 2017 10:08am
