Home > Technical (L322) > Lack of power - S/C
Page 3 of 4 <1234>
zarnd
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Bonatti Grey
My gearbox is not great and bangs into gear when stationary etc...
You have been thinking along the exact same lines as I have with regards to the MAF etc...
Will call LR today and see where we are with it.
cheers Alex
2018 Skoda Kodiaq vRS
2009 Caterham Supersport Race car
2007 M5 Touring
2005 Range Rover Vogue SE Supercharged
2004 SL55 AMG
Post #444762 17th Jul 2017 8:30am
zarnd
Only other thing that has happened recently is running out of petrol and reduced engine performance on the dash because of no petrol before it cut out. However, LR have said no faults or unable to find anything wrong with the car. However, they can hear the noise and have heard it on the video I have sent to them.
This is beyond frustrating as I asked on Friday if they could open a technical case with LR, and here we are on Monday and they still haven't so I have asked again for this to be done.
I have tried contacting Powerhouse but there phones say they are closed.
Trouble is, I'm convinced it is something relatively simple that is the cause.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #444769 17th Jul 2017 9:33am
ebajema
The running empty of the tank could have caused a problem although I'd expect fault codes related to that.
First it could have sucked crud from the bottom of the tank that clogged the filter (the fuel pump is installed in the tank and has a filter on it). This could restrict flow of petrol but I would expect fuel pressure to be low (fault code) and it doesn't explain the higher fuel consumption.
The other option (again should throw up some code) is air in the fuel injection system causing some injectors to now work well and some to work harder to get the car moving. Not typical for petrol cars but maybe.....
Water in the tank (built up over the years) into the fuel injection system causing issues but again should cause some fault...
I would have a look at the tank, open it up and see if it is clean and waterless. Maybe replace the filter while you are at it.
It is probably a long shot but hey, could be worth having a look.......... MY 2010 5.0 SC Galway green and sand interior!!
Post #444772 17th Jul 2017 10:55am
zarnd
It is certainly worth asking the question.
I wonder if there could be air in the fuel system and that is the noise I am hearing behind the glovebox?
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #444776 17th Jul 2017 11:13am
Crispian22
Having a quick look on the internet,there have been a few reports of front diffs making the noise you describe.Diagnosis seems to be to drop the car into neutral at speed when it makes the noise,Not something I'd do personally,but if the noise persists then you know it's not engine related.
For the sake of half hour,i would whip the aux pump off to double check it is running the correct way,as it doesn't log any fault as in your situation.
Post #444777 17th Jul 2017 11:17am
ebajema
I can't think of a mechanism that would cause it but that doesn't mean it can't have happened.......
Lets hope it is something that simple Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #444778 17th Jul 2017 11:17am
Crispian22
Also reports of alternator bearings and water pumps on the way out.
My money is on the aux pump being fitted wrong Thumbs Up
Post #444781 17th Jul 2017 11:22am
zarnd
Ok, will suggest it to LR to have a look at.
Spoke to someone very helpful at powerhouse reference the issue and they were pretty certain it would not be anything to do with the supercharger - so rules that out to a point. However, if the car ever gets fixed then I will certainly be changing the oil in the supercharger as it has never been done before.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #444791 17th Jul 2017 12:27pm
zarnd
Have also had a new alternator as it failed completely after whining away for a few months and not the same noise as before. Alex
2007 M5 Touring
2004 SL55 AMG
Post #444792 17th Jul 2017 12:29pm
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Could it be that the backfire damaged the catalytic converter on the passenger side when you ran out of fuel and that's causing the restricted performance and the noise?
Just a thought, as I have my fingers crossed that I haven't damaged mine, as I ran out of fuel for the first time with an indicated range of 40 miles, which threw up a restricted performance and engine warning light fault, stating Catalyst not operating adequately. I've had the fault cleared and am hoping that it doesn't reappear.
Post #444793 17th Jul 2017 12:33pm
zarnd
Possibly yes. I had a thought that the nearside cat had broken up and was partially blocked and air noise was exhaust gas coming back up the pipe again.
If LR come back with nothing then I will whip out a sensor and poke a camera down the exhaust. If the cat has broken up then that would answer it.
LR finally seem to have raised a tech case with regards to my car.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #444795 17th Jul 2017 12:59pm
ebajema
Be carefull taking the sensors out, the threads are easily damaged. Use plenty of lubrication or the stainless steel will "bite" badly !!! I had to rethread the exhaust hole on my SC 4.2. MY 2010 5.0 SC Galway green and sand interior!!
Post #444895 18th Jul 2017 9:43am
zarnd
So LR still cannot get to the bottom of this presently. They have sent a technical case to Land Rover who have not come back with anything useful.
At present we are all stumped.
They road tested the car and could not get the noise to occur but did say how the fuel gauge was almost moving whilst the car was being driven and is using a lot of fuel.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #445031 19th Jul 2017 12:57pm
xjsracer44
How did you get on with your inspection of the cats?
My engine warning light reappeared & the fault came up as both cats, so they are being replaced on Friday.
My fuel consumption was also rising noticeably, but was told that this was due to the ecu going into default mode and overfuelling once the warning light reappeared.
Post #445058 19th Jul 2017 4:07pm
zarnd
I haven't checked them, yet.
Thinking about it, there could be an issue with one or more of the injectors. This would explain why the fuel is increasing and also the noise could be from one of the rear injectors near the bulkhead. When I worked at VW the T4 used to suffer with number 3 injector failure and with the copper washer fitted they used to chuff like a steam train at idle so wondering if the noise is caused by a leaking injector. This is why, at the moment, I am not going down the road of failed or a blocked cat. I also think if one was blocked and the other ok, then you would see that one was getting a lot hotter than the other when looking at them from underneath. If it was my cats, I would cut them out rather than replace them.
Still, it is somewhere to start and a sensible place to start as well without any fault codes.
Fingers crossed something comes of the injector leak-off test.
cheers Alex
2007 M5 Touring
2004 SL55 AMG
Post #445127 20th Jul 2017 10:11am
Page 3 of 4 <1234>
