![]() | Home > Maintenance & Mods (L322) > Front mounted towbar. |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Could have been worse... 2006 Mercedes CLS 1991 Retro-style Mini But really finding it hard to fight the urge for a S/C... |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 ![]() ![]() ![]() |
Well mine arrived today. It ia a Watling brand and having looked over their site and literature .. and got on my back under the front end.. it will require a cut to the front sump guard... a term which I use loosely as its not really a sump guard. Just some trim. Well its certainly not like the sump guard you would expect to find on a defender for instance.
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
I wonder if, as the draw is removable, you could use the same front tow bar fitting with a recovery peg............ like you can with the rear tow bar. El how does the front one mount onto the chassis? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Havank Member Since: 05 Apr 2007 Location: Woking - Surrey Posts: 193 ![]() ![]() ![]() |
We have to agree to disagree. I can turn my twin axle trailer 360 degrees on his own axis. you push the bar down, so its on two wheels, its all a matter of balancing my friend |
£75,- for a towbar is cheap |
Four humoungous bolts through the chassis... If you lay down and have a peep you can see two holes pre drilled through the chassis and apron/shield. A wild guess would be this may be where bull bars mount.The other two holes are further towards the front.. and as yet I don't know if they are already there or require drilling as the sheild covers them. Watling do a winch and attachment for winching the likes of caravans and boats up driveways / slip ways. Advantage being you can attack it to any tow bar... front or rear.
![]() Oh hang on... I can do it with my corgi toy car trailer as well. ![]() Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy". |
Ok .. earlier I emailed Watling being very cheeky to see if they would be kind enough to forward any instructions. What do you know! Ben at Watling kindly replied sending me the instructions.. now that is beyond the call given I bought second hand so hats off to Ben |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35599 ![]() ![]() |
sounds like an interesting project, when looking for the tools dont forget the camera.. ... - .- -.
I wonder if fitting this will have any effect on your secondary restraint systems (airbags and pretensioners) and pedestrian safety at MOT time? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
As for pedestrian safety.. It's no more dangerous in my opinion than the central recovery hoop.. bearing in mind you wouldn't realistically be driving around on the road with the towball on the front. The bracket has a rubber bung simlar to the rear tow point.. so again I guess.. depending on your point of view its equally as dangerous as an empty rear tow reciever should anyone reverse over a pedestrian. Cycle carrier / trailer / caravan etc etc
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
massive thread bump but do you have any "after" pictures of fitting please? I'm wondering just how far down/vulnerably it hangs under the front tray... NW060
Sorry Mat, I never got around to fitting it.. the FFRR was sold on.
