Home > Maintenance & Mods (L322) > Transmission Flush
Has
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Transmission Flush
Hi All
Long time lurker, had to star up and post due to a necessity Razz
My rig has coincidentally reached 100k and 10 years at the same time, time to spend the big bucks.
I'm after Geoff or Mike, do they still do them trans flushes?
Also changing all the oils, any advice on LR Dealer supplies compared to other brands elsewhere.
Shopping list seems to be:
Spark Plugs
Transmission filter and oil
engine filter and oil
brake fluid
coolant
transfer box fluid (also locking diff?)
axle diff fluids
and any or all sump/drain/fill plugs needed.
Priority is getting hold of Mike or Geoff but any advice would be most appreciated Thumbs Up Bmw E36 328i M Sport Cabriolet
Range Rover Sport Supercharged - Sold
Aston Martin DB9 - Sold
Range Rover L322 Overfinch Supercharged
Lamborghini Gallardo Spyder - One find Day... Razz
Post #442025 19th Jun 2017 6:59pm
Has
Hi
Lots of views but no reponses Crying or Very sad
Further to the conversation I am now getting conflicting information in regards to the gearbox flush and could do with some professional advice or opinions.
Been told by transmission specialist garages that
1. Running the engine for a minute and extracting the oil through the oil cooler pipes is the same.
2. Putting any type of cleaning detergent through the gearbox is asking for trouble as remains of it will breakdown the new ATF oil.
3. There is no need to do a full clean flush as if there are any 'bits' inside the transmission it needs repairing anyway and a flush is not going to help. If no bits no flush necessary.... Neutral
Any views on the above would be most appreciated as I am now totally confused as to which direction to go Confused Bmw E36 328i M Sport Cabriolet
Post #442308 22nd Jun 2017 3:36pm
Big Boy R44ROV
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
Think i'd rather flush and drain it properly via gravity than vacuum pump it out. And as for flushing, it seems to make sense to me. I flush the engine every time I change the oil, so I would do the same with the gearbox. Especially considering the cost of a new box or rebuild.... Whistle Tony
You're always in the Censored ........it's just the depth that varies
2011 5.0 Autobiography Fuji White
2019 Audi Q2 in White
04 SL55AMG
Gone:
07 4.2 SC in silver.
06 4.2 SC in black RSE
RRS 4.2 SC in Black RSE
52 4.4 Vogue in silver
04 Mercedes CLK 320 Conv
03 4.0 V8 ES Disco in Silver
00 TD5 90 County
98 4.6 HSE in Epsom x3
97 3.9ES Disco
93 L 4.2 LSE in black
too many classics to mention !
V8 Lightweight
Too many series to mention !
IID for L322
Post #442309 22nd Jun 2017 3:48pm
Has
You've made a point there Big Boy, if the additives that flush the engine are not harmful to the engine oil then surely the same goes for the trans cleaner... Confused Bmw E36 328i M Sport Cabriolet
Post #442313 22nd Jun 2017 3:57pm
Big Boy R44ROV
I'm led to believe the 'flush' is basically using double the amount of ATF needed. Drain. Fill. Drain. Refill. Plus filter of course. Depends on the gearbox type as to whether you can replace with the metal or plastic sump. Thumbs Up That's why it's expensive!! Tony
04 SL55AMG
Gone:
00 TD5 90 County
97 3.9ES Disco
V8 Lightweight
IID for L322
Post #442314 22nd Jun 2017 4:04pm
Has
Yes that's the double flush, that is fine no problem. It's the so called mega flush which uses the Wynns or Fortron machines which the tranny garages have a problem with. (Oops that last bit came out wrong Whistle ) Rolling with laughter Bmw E36 328i M Sport Cabriolet
Post #442315 22nd Jun 2017 4:07pm
hamlet
Ireland 2006 Range Rover HSE Td6 Buckingham Blue
This might help.
http://www.fullfatrr.com/forum/topic26491.html
Post #442316 22nd Jun 2017 4:14pm
Big Boy R44ROV
PMSL!!! That must be why the Tranny garages prefer to suck it rather than let it dribble out of the bottom Laughing Rolling with laughter Rolling with laughter Rolling with laughter Tony
04 SL55AMG
Gone:
00 TD5 90 County
97 3.9ES Disco
V8 Lightweight
IID for L322
Post #442317 22nd Jun 2017 4:14pm
Has
Oh Nastyyy Censored Twisted Evil Bmw E36 328i M Sport Cabriolet
Post #442319 22nd Jun 2017 4:29pm
Has
Good write up in that thread Hamlet but that's what our 'boys' Laughing in the gearbox garage recommend however my question is probably more to the mega flush guys, is the machine way better than the DIY procedure Hamlet has just linked to?
Is there a benefit of one over the other? Bmw E36 328i M Sport Cabriolet
Post #442323 22nd Jun 2017 5:54pm
Big Boy R44ROV
I think the simple answer is....if there is any doubt then don't do it. Stick to the recommended way.
I work in Safety. I usually say to people, if it doesn't look or feel right, then it isn't. So don't do it! Thumbs Up Tony
04 SL55AMG
Gone:
00 TD5 90 County
97 3.9ES Disco
V8 Lightweight
IID for L322
Post #442324 22nd Jun 2017 5:59pm
Has
Service Bits
After spending countless hours doing research worked out what some of the original LR dealer service parts are and best place to get them which could be useful to many here:
Transfer box fluid IYK500010 is actually Castrol BOT26 and cheapest is Rimmerbros at £16
Locking diff fluid LR019727 is Castrol BOT720 but can't find that anywhere
Axle diff fluids TYK500010 is Castrol SAF-XO cheapest is OPIE at £15.95+VAT
Spark Plugs are NGK IFR5N10 cheapest eBay
Transmission Oil ZF Lifeguard 6 cheapest eBay Bmw E36 328i M Sport Cabriolet
Post #443524 4th Jul 2017 3:30pm
Dreckly
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
If you speak to Chris at Opie he will look after you. I was talking to him about Lifeguard 6 and Castrol Syntrax for my L322 earlier today. Tell him Ken at Milestone Motorsport recommended him. They apparently will price match and £17.75 is the cheapest I found for Lifeguard 6.
Cheers,
Ken 55 S/C L322 Zambesi Silver.....GONE!!
56 S/C L322 Java Black......surviving at present...just!
04 N/A 4.2 V8 S Type Jag
1961 reg 3.5 V8 Bowler Tomcat.....Sold
Numerous Classic (rusty!?!) Minis
Post #443610 5th Jul 2017 11:42am
Has
Nice one Ken, will give him a call Thumbs Up Bmw E36 328i M Sport Cabriolet
Post #443690 6th Jul 2017 12:17am
Has
Air Filter
Any advice on air filter, dealer versus oem non genuine etc? Bmw E36 328i M Sport Cabriolet
Post #444143 10th Jul 2017 3:54pm
