Home > In Car Electronics (L322) > Navcoder help please
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I bought a lead off the bay down loaded beta version and seems to connect to the car ok but when I try to scan get no response from modules have tried both bus settings and still zilch any help appreciated please.
Post #443299 2nd Jul 2017 2:48pm
Have you read this:
http://www.navcoder.com/downloads/Readme.txt
Note the developer doesn't use/recommend an OBDII connection, but prefers the Reisler I Bus interface
I may stand to be corrected, but the trial version won't give you much in terms of functionality, things improve once an activation key is purchased?
If you bought a lead like this:
http://www.ebay.co.uk/itm/BMW-DIAGNOSTIC-S...SwH09ZIMjC
It already comes with a Navcoder trial....
When you connect run the program, you should see a load of ibus messages go by? .
Post #443305 2nd Jul 2017 3:34pm
mjdronfield
If I remember right, the trial version just reads, it can't change settings..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #443311 2nd Jul 2017 4:08pm
horsedentist
Joe90 wrote:
Have you read this:
Thanks for that I will buy one and give it a go maybe it is the lead I bought.
Post #443322 2nd Jul 2017 5:58pm
horsedentist
I will order one of those leads and try that. Thanks for the link.
I know you have to register the software to change things just wanted to make sure it works before buying it.
Do you have to register to pair the phone as well??
Post #443323 2nd Jul 2017 6:01pm
Pair phone, yes. I used Navcoder to do this instead of the touching of wires (because I had Navcoder already!)
I have a Reisler for my Navcoder connection, it will take a bit of fiddling about in the boot to make the connections but it works fine.
Details on connecting up can be found here http://www.fullfatrr.com/forum/topic8786.html
somewhere in the middle of the first page .
Post #443324 2nd Jul 2017 6:06pm
Oh, and do yourself a favour when installing the ULF. The code is on the underside of the unit. Write it on the top of the unit before installing, will save a bit of trouble when you forget what it is! .
Post #443327 2nd Jul 2017 6:19pm
horsedentist
Have done that already lol
I installed it over the weekend can't test it yet as I bought the ulf and the antenna from different places and the antenna is still to arrive. The modules in and all repinned and shows activate phone on the computer so hopefully all has gone well so far, fingers crossed.
Post #443333 2nd Jul 2017 7:10pm
horsedentist
New lead works fine but have problem with the ulf instal no audio in or out. Mic not working and no sound through speakers.
Post #444433 13th Jul 2017 7:26am
