Home > Technical (L322) > Mysterious *clunk* when braking...
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Just had a full 10 year service and the brakes and suspension done on my TDV8. It then passed its MOT with flying colours..however, for some months before I have had a clunk when coming on/off the brakes at lowish speed...it seems to disappear only when the weather is dry.. but even after all this work it remains a fixture and is driving me up the wall..no one seems to be able to identify what it is. Any pointers anyone please?
Post #443026 29th Jun 2017 9:08am
jonnyboy54321
Sounds like classic lower arms. What suspension work was done? 2007 Vogue TDV8 with 255/55/20's fitted
Post #443029 29th Jun 2017 9:41am
Zeb
She had two new rear dampers and a ball joint. They said they could find nothing loose or amiss other than that..and to be fair, neither could the MOT guy!
Post #443039 29th Jun 2017 10:59am
JPJ64
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I had the same 'clunk' on mine. Diagnosed as a front drop link. Had both replaced and she's now as quiet as a 3.6V8 diesel mouse could ever be Very Happy
Post #443042 29th Jun 2017 11:12am
Zeb
Got to admit that it sounds / feels like the issue is at the rear..but I have been wrong about such things before!
Post #443045 29th Jun 2017 11:19am
daz62
United Kingdom 2003 Range Rover Vogue SE 4.4 V8 Oslo Blue
I have had this, "clunk when braking" twice on my car now, both times it has been the lower rear hub bushes.
See this thread for more details http://www.fullfatrr.com/forum/topic435.html 03 4.4 V8 petrol / lpg. 1st of many hopefully. I love my Rangie
Post #443056 29th Jun 2017 3:52pm
sako243
Are the caliper bolts done up correctly. If it's clunking when braking, notably when changing direction it could be that. Ed
Post #443074 29th Jun 2017 8:25pm
Zeb
Well the noise has disapoeared again niw the weather has dried up! Will try spraying the bushes and see if that makes a difference. Calipers were all checked by the garage.
Thank you fir the pointers so far!
Post #443566 4th Jul 2017 9:06pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I had the same noise on mine for 6 months, it was the lower arm at the front, but the one towards the rear.
It's a PITA to change but once you've done it, you'll kick yourself and probably realise there is an easier way (as I did)
I changed the arm and the balljoint (they come as seperate parts) and the noise stopped!
Post #443600 5th Jul 2017 10:01am
