Home > In Car Electronics (L322) > Bluetooth upgrade on l322
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
Hi Guys
I have sourced all the bits I need to have a crack at upgrading my phone system to bluetooth but missing the lead that connects the ulf to the antenna block. Drawn a blank at bmw as they say they cant access the lead on their system without a vin number.
Does anyone know if the existing antenna lead from the old telephone module will fit and work ?
Or do I have to find an X5 bluetooth one.
Cheers
Post #442924 28th Jun 2017 8:57am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
From memory this cable is in the loom if you had the original phone fitted
Are you working of the white cable block or the 50+ pin block?
Right at the back of the car left hand side remove the cover and look backwards towards the rear light electrics, there should be a small loom 3/4 wire in it, one has open end and the bottom and one at the top
Post #442951 28th Jun 2017 2:20pm
horsedentist
Hi
Yes I know where it is can see it running up to the existing antenna. I haven't started stripping it out yet wanted to know if it will fit the.new ULF and antenna as I tried to get a replacement just in case it didn't but haven't had any luck. Most scrap yards cut the wires and BMW say they can't find it as a replacement item.
Post #442974 28th Jun 2017 6:50pm
