Home > In Car Electronics (L322) > Reverse camera repair / upgrade |
hamlet Member Since: 18 Nov 2016 Location: Kildare Posts: 294 |
I've retro fitted a few different types of cameras and I've used one similar to the link before and found it good.
9th Jun 2017 12:13pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 898 |
It's a pity they don't make the reverse cameras that tie in to the steering position collar and show you where you will reverse to depending on the steering angle.
10th Jun 2017 6:33pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
The only issue with fitting a camera in the bumper is a) you have a hole in the bumper, and b) with the camera in such close proximity to the towbar you'll end up with no depth perception, and I would be happy to put money on it that it will end up in making hitching up a trailer near impossible, and could end up in as you hit the bumper
11th Jun 2017 10:49pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3542 |
mpirie doesn't your 2011 have exactly that? Mine does. . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
12th Jun 2017 6:47am |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
I'm going for the number plate light mount I think. It's not LR factory and that grinds at me but it is more usable and a better angle for hitching up. Next step is to undo all the loom feeding the spoiler and rewire....that's a weekend job !! Is this where I put the car details and a bit about myself ?........ |
12th Jun 2017 7:55am |
No, I didn't know you could get that option on the L322 |
12th Jun 2017 8:49am |
I didn't fit it on a FFRR, it was a Navara.
12th Jun 2017 12:01pm |
12th Jun 2017 5:53pm |
chubbs358 Member Since: 26 Jun 2017 Location: orkney Posts: 6 |
i have fitted a replacement rear camera i got off amazon all seems to be working well just needs adjusting up a tad so it is looking back more and less down to the ground, good clear picture, led's working and the park asset lines as well witch i didn't even realise it had. i fitted the camera by modifying the original camera wiring as the original cam was past repair this kept the car side of the loom untouched. the only problem i seem to have is it is automatically zoomed in when selecting reverse but i can change the aspect in the 753 menu, does anyone know if i can set/change the aspect when selecting reverse or could it be the type of cam i got thats the issue? car is a 2005 (55 reg) 4.2 SC with touch screen. any ideas would be much appreciated, thanks
26th Jun 2017 10:35pm |
wizhas Member Since: 02 Sep 2017 Location: Dubai Posts: 2 |
Chubbs I have the exact same problem. After all the work of installing the camera, this is driving me insane! |
2nd Sep 2017 5:06pm |
Just had a look at the link ^ it says PAL/NTSC... that might be where the problem lies.... the ffrr uses NTSC only, maybe the PAL compatible part is zooming up your picture
2nd Sep 2017 9:13pm |
PAL/NTSC could very well be the problem, I should have mentioned before that I used a slightly different camera which is similar to what the earlier posts were using. To be honest after all this work I cannot be bothered to fit another camera. When installing the camera I was using the Video Inputs Test in the 753 Menu to align it. When I put the car in reverse I believe it digitally compensates for the physically high and off centre position of the camera. We need to find a way to turn off this automatic digital correction or set the correct view since the 753 menu only shows us what it looks like but does not allow us to save the option. Reversing view (red guide lines are out of view and the lines are slightly moved to the right): 753 Video inputs test view (Perfect alignment without moving the car) : |
2nd Sep 2017 10:23pm |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
Just bought one of these and will have a go:
3rd Jan 2018 5:18pm |
This one did the trick - you can call them and confirm you need NTSC only.
28th Jan 2018 9:30am |
