Home > Duckworth Parts > Abs module
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Abs module
Dan, just found out that the abs module on our 2003 petrol L322 is faulty. Main dealers are quoting 3500 for a new unit then up to £5000 total for labour.
Are they that expensive.? Do you have any prices?
Post #442526 24th Jun 2017 9:25am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
You can have yours repaired / rebuilt for a fraction of that cost. I actually bought a guaranteed used one and have had no problems in the 10 months since fitting it. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #442529 24th Jun 2017 9:40am
PaulTyrer
Simon, do you have any contact details of places that can do that?
Post #442535 24th Jun 2017 10:15am
dingg1
plenty second hand ones for sale on ebay , quite easy to change out - make sure all the numbers match up before buying one though
Post #442542 24th Jun 2017 10:44am
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
My ABS ECU/Module failed, My range rover specialist got replacement part from breakers yard they use and charged me £150 for the part. which was about what they go for on ebay.
There's no way i can recommend buying these items new these days new. some of the cars ECU's new are worth more then the car itself. 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #442554 24th Jun 2017 11:43am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Is your abs unit deffo fubarred?
I only ask because My abs lights etc all came up a long time ago and so asked bristol stealer to have a look - came back 40 mins later and said it's f@cked, need a new abs unit at over £1500. I queried it and looked myself. They hadn't even taken the abs plug off to look. A little bit of green corrosion on a few of the pins. Toothbrush and electrical contact spray and all is good 40,000 miles later.
The female Plug in is very badly designed because as it's inserted upside down, it catches and retains water in it. Cr@p design.
As others have said, get another unit from another car. There are plenty 2003/2004 v8 petrols sitting around. 👌
Post #442561 24th Jun 2017 12:09pm
UK Marine
You could try these people
http://www.actronics.eu/en/shop/land-rover...abs-ecu-en
I don't know their prices but there are quite a few repairers out there..... ______________________________
Simon
Post #442564 24th Jun 2017 12:42pm
PaulTyrer
@dolphinboy. The brakes are OK, we were getting warnings for abs, hdc and dsc inactive, dealers told wife thar the abs pump and modulator are at fault but now we don't get any warning lights on. I'm only home at weekends and whatever I suggest to do on the car is always wrong!
Post #442653 25th Jun 2017 10:36am
dingg1
my well respected independent in newcastle told me the same , they also told me they had repaired the loom , the problem was a wrong spec abs wheel speed sensor had been used NO abs module was required at all, don't trust your dealer IMO . do as said above check the multiplug for corrosion use some contact cleaner and see if it that sorts your issue first.
Post #442654 25th Jun 2017 10:51am
UK Marine
Or......if in doubt send the ABS module to one of the repairers and they will check it for faults for a nominal fee.
The faults on mine only showed up after driving for around for about 5 - 10 miles, and from what I understand from reading the BMW forum entries its the heat and vibration that expand the solder joints causing it to fault, and only after cooling down, say overnight, the solder joints would retract and all would be well - ish.
Good luck.. ______________________________
Simon
Post #442676 25th Jun 2017 5:49pm
duckworthparts
Site Sponsor
Paul,
that dealer must be plucking figures out of thin air.
still they're not cheap
RRP on a new unit £1815.00inc vat
forum price £1452.00inc vat You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #442731 26th Jun 2017 10:17am
PaulTyrer
Thanks Dan,
Seems that they have replaced a steering angle sensor on the column and the ABS unit was throwing errors after about 10 minutes of driving, however it doesnt seem to have done it since we got the car back at the weekend. I'm wondering if it could just be dirty connectors as the reply above as during the MOT the battery was disconnected for a while and it went into transport mode!
Paul
Post #442746 26th Jun 2017 11:53am
